Root [ROM] Android 2.2 FRF84B (Clean, Untouched, Virgin)
I'm loving this ROM, super fast. I have a problem though, I don't seem to have flash. I went to miniclip.com and couldn't play games. Anyone else having flash issues?
Is anyone still running this? I'm having a hard time finding something that will stay stable for more than a day or two. I don't think I run alot on my phone, I only sync FB with my contacts, and have 3 email accounts and the phone will run fine for a day, then it starts lagging crazy! Anyway, I'm thinking of going to this and running the stock kernel, hows everyone experience with it?
No, I switched to Kangeraid 4.0.7. 99% problem free.
All Froyo gives Google Listen problems on my phone :(
This worked fine for me, no problems. But after trying several overclocked ROMs (and experiencing similar problems as you did with stability) I find that Sapphire 0.7 with the 1GHz Low Voltage kernel is fast, smooth and very stable. And it looks beautiful with the Blue Energy theme (I'm using the EV special without the clock and running Beautiful Widgets for time and weather).
How the battery life? And did you download the kernel right from their site?
Battery life is no better (or worse) than any other OC ROM running a custom theme. Kernel is P3Droid 1GHz LV (available on his site, or automatically installed if you flash with ROM Manager).
im running this with stock kernel cause i tried a few different kernels and battery got real hot and i really like it so far, had on for a few days...
if im running this rom will it automatically update to 2.2 when it comes cause i am really happy with this and dont want it too.....
I would think that since the system is untouched, the OTA updates would still be enabled, which means that, yes, it would update once the real Froyo comes out.
thank u for answering..i got to figure out how to disable that, i got my phone set up the way i want....
I can't seem to find what Froyo 2.2 gives me. Is there a straight forward list of what 2.2 brings to the Droid?
I just received my OTA software this morning.
