Why would you miss that P. O.S ?
Single core ... Horrible battery.....
Added lines to build prop .. Still no go on MMS. I ALSO TRIED MMS FIX
Mantera, Whyzor, Bsydz, G60, Mobster, Ziggy, Chairshot, and Ganon.Reflash. Add lines to build.prop. Open Voice Dialer and say "Open APNS" and make sure its selected. Also make sure the mmsc field is correct, which it SHOULD be.
And why? Some of the best dev's were on that phoneMantera, Whyzor, Bsydz, G60, Mobster, Ziggy, Chairshot, and Ganon.
Gotta try this out sometime, thanks G60!Don't forget Tickerguy, our CM7 saviorGotta try this out sometime, thanks G60!
Also Bootloader is now listed after turning on Developer Options
Google Now seems to force close every time I try using the voice commands. Anyone else having this issue?
Same issue here, went the play store and updated and working perfect now.
o.o
Horrible pun. Don't quit your day job![]()
I look forward to this ROMI'm excited to see you back in action G60!I look forward to this ROM
I'm currently running wild for the night, and since you said they are so similar right now, I'll probably wait for a few updates before installing this.
I've always been a fan of your work. You worked miracles on the Triumph!
I noticed that GPS isn't listed as a bug. Does this mean it's working fine when the March10th zip is flashed, or do we still need to do a few things after the flash to make it work?
Is the kernel used the same kernel as Dastin's CM10.1?
