Add me to the list, I'm not receiving MMS. Anyone had success recovering from a no-MMS state? Have tried APN restore and other VVM fix package so far.I am having mms problems now too.
Yeah, I edited my APNs a while back, and have used "APN Backup & Restore" to restore them when I've had problems in the past. I'd already done that, and my MMSC setting is already set to that value.I have always had MMS in/out problems. Despite the ROM adding is fixed or included. The only way I get around it is using voice dialer to "open APNs" then adding "http://mmsc.vmobl.com:8088/mms?" under MMSC in settings. Works every time.
I've had 3g active at various points (when my 4G signal hasn't been strong enough somewhere, but haven't seen yesterday's MMSs come through.coolblood2 said:I have been able to send and receive MMS but I have to make sure that my 3g is on before they send me a MMS though.
Hey Guy's, stupid question on my part,I should know this, but how do I install the rom without Google restoring all my old apps? I do want all my contacts though.Oh yea. Luv the rom. Thanks Guy's.
Also, how do I update the PRL? I saw this as a possible fix to my SMS issues...but all the menu settings from previous ROMS are gone in this one.
Only with stock rom.
Mostly during reboots.
Hmm. Do you have Google maps installed by chance? I was seeing drastic drops in battery life during use and on reboots until I unchecked "report from this device" in Google maps' location settings. I had previously unchecked this, but when the app was updated it renabled the setting.
I do.
Check that the "report from this device" setting is unchecked. In the Google maps app it can be found under settings->location settings
My experience doe's not interfere with Now at all. Just leave location history checked and location reporting checked. As long as you have enable sharing unchecked you should be OK.If you are referring to the travel times, I'd say only marginally. I usually dismiss it because I know how long it generally takes to get between those locations at most times of the day (commuting bites ha).
One thing it does that's pretty useful is giving you travel times to some place you have searched for. For instance, a few weeks ago I searched for local drive in movie theaters on my laptop and found an interesting one close by. When I picked up my phone after I was done, Now told me how long it would take to get there from my current location. A little creepy, but cool nonetheless ha.
But I would definitely recommend turning of the device reporting setting I mention earlier. I was only get about 6-7 hrs battery life tops before I turned it off, but now I'm easily getting triple that. In the time I had it enabled, I saw zero difference in the way Now behaves.
