Root [Rom]AOKP For Motion[Port]
How does one so this? Also I love this ROM thank you so much. All we need now is in ear volume. Awesomeness!!!
I was eager to install this because I miss Cm10, but with no gps and horrible volume it was not practical.
then I see something abour the load screen says "initiating swagger"?
No thank you
No thank you
Ehh what? Are you serious? Dude Aokp is very similar to Cm10. Only difference is that with aokp there is so much more customizing and tweaks that you can have work towards your favor. Hence the "initiating swagger" part. Hey its worth a try. Try it out and see if you like it or not. No harm done!
No thank you
Never judge a book by it's cover, because if you do you'll never experience how amazing things could be ;p
The swagger thing is a joke. There is also a toggle in the notification bar called swagger, its the hat. Once you turn it on, you can't turn it off. :p (get it?) lol
Aokp is based off Aosp, and has a ton of awesome features that you won't find in cm10. You could always change the boot animation.
:rolleyes:
Anyone that has their phone get all "hot and bothered", hold your power button, when the menu for reboot, power off, etc., and look at "Airplane Mode". If it says "Airplane mode is ON" underneath it, turn it OFF, then reboot your phone. Once your phone reboots, verify that Airplane Mode is still listed as off, and it should stay nice and cool without use.. I had the same problem, and the battery wouldn't charge while it was super hot either, and this was the culprit.
EDIT: another thing, if you guys use Swainsmith's GPS fix, that might be causing the overheating too.. I have noticed that since I applied that, my phone gets hot. And even when I deactivate GPS, it still persistently says "Searching for GPS..." and I can not dismiss the notification.
I know what aokp is
I'm just saying
I'm tired of this yolo/ swag crap
Ty for your motion efforts
I'm not knocking it, maybe I'll just change the sxreen ....and the hat
Thx appreciate it I love this rom but keep getting the cpu pegged @ 100% usage for no reason
That could happen from a crap app stuck running in the background. This happened to me on a different phone with an app from the play store (forget which). As soon as I removed it, problem solved.
One of the apps installed is not running well, just got to find which.
I'm having trouble rebooting into recovery. I hit the power button - reboot - recovery. The LG screen blinks like it's going to let me go into the recovery but instead the boot animation comes on and stays that way until I pull the battery. Tried again and again but nada.
