Root [ROM][AOSP][Alpha] LiQUIDSMOOTH-v1.4.3 RC2 | Android: 4.0.4 | Date: 5/28/2012
Austrie
Android Expert
download.php
Rom Features
  • !Theme Chooser!
  • Full Screen Mode
  • Extremely Responsive UI
  • Customizable Battery Icons
  • Center Clock With Customizable Color
  • Now Includes 5 Lockscreen Options
  • Retain Your Personal UI/ROM Customizations
(Note This Does Not Apply To Any Of The Settings Under The Goodies Section)
  • Allows Customization & Optimization Of Nearly Every Area
  • Quad/Octo Lockscreen With native/(customizable) ICS Icons
  • Customizable Navbar Background Color, Button Glow, Height, Speed, Colorkeys
  • PropModder, A New Convenient Way To Edit Your Build.prop With The Flick Of A Finger!
  • Native Overclocking/Undervolting Performance Utility
  • Native Gamma/Color Control
  • Uniform ICS Theme Throughout The ROM...
  • And Much Much More!
It is with great pleasure that we are here to announce the arrival of LiquidSmooth V1.4. V1.4 is without a doubt a Milestone release for us. It brings to the table unmatched customization and usercontrol; while providing excellent battery life, not forgetting rock hard stability & speed only a Liquid Smooth ROM could deliver. It truly marks a step towards the goal of our project to bring slim, flawless firmware to the phones of LiquidSmooth ROM series; to get the utmost out of your phone! A very big thanks you to our beta testers ; IRC channel community members / Liquid Smooth family, as well as all of you here at the Triumph Community! The entire Team Liquid is stoked about this release for the triumph; we are certain that you'll love it too! Please, enjoy! Also, stay tuned, as 1.5 is in the works as I type...
Working
Everything Working In CM9/AOKP
Preinstalled Apps
GPS
WiFi
Data
Audio
RIL(Calls)
Messaging
Wired Headset (Third-Party App)
WiFi Tethering (Third-Party App)
USB Tethering
Hardware Acceleration
EVERYTHING ELSE NOT IN 'NOT WORKING'
Not Working
HDMI
Camera
Netflix Streaming
There are no known bugs, besides Theme Chooser Force closing. Going to fix soon; if you should discover any other bug, please send a message with only relevant data to: yoyo.rom.dev@gmail.com. :-D Also, if you guys have a concern that we cannot address here in the triumph community, or you'd like to contribute a great new idea for improving our project, we welcome you to join us @ IRC.FREENODE.NET; #LIQUIDS.
When you donate to LiquidSmooth, you get to use updated versions of the ROM before we release the full version...
Instructions
Don't Flash Gapps
Place the zip file on your SD Card, preferably in the root(not inside any folder) of SD Card
2. Reboot your phone into ClockWorkMod Recovery V5.0 (CWM).
ClockworkMod Recovery for Motorola Triumph
or here:
[GUIDE] Installing CWM and a custom ROM on the Motorola Triumph
3. In CWM "Wipe data/factory reset"
4. In CWM Go To "Advance", Then "Wipe Dalvik Cache"
5. Go Back To Main Menu And Select "Install Zip From SD Card"
6. Then Select "Choose Zip From SD Card"
7. Select The ROM
8. !Reboot & Enjoy!
Download
http://www.mediafire.com/download.php?xxi0m06omicea24RC2: http://www.mediafire.com/?ylbvr7jb90k67s9
Screenshots
Austrie's Performance Add-ons
http://www.mediafire.com/download.php?2gl94ft4y5jd42f
- Contains -
HWA Changes
Data Speed Tweaks
Build.prop Changes
Touchscreen Changes
Internal SD Card Feature
Data Base Defragmentation
Daemon Controller App
SD#2.zip
- Contains -
Everything In SD#1
Memory Management Changes (Results May Vary)
SD#3.zip
- Contains -
Everything In SD#2
LowMemoryKiller Changes (Results May Vary)
The reason I put up three different choices, is because 2 and 3 contains changes involving how the ROM handles multitasking. SD#1 is basically the base for SD#2 and 3; but is guaranteed extra performance, hands down. SD#2 and 3 vary from user to user, some people may like; and other may not. That's why we have separate zips
THIS. LOOKS. YUMMY! Only thing I'm also waiting for (as are most people) is the camera. Once that is working, I am TOTALLY jumping on this! Very very nice Austrie! =]
comming from cm9 latest version do need to clear data /reset in recovery? or will i be ok to just wipe cache im downloading now
i bet the camera fix will be found the day i sell my triumph for the evo v. which is soon.
trust me, i have THE worst luck in the entire world, its basically predictable at this point, so ill make sure to sell my phone asap so you all can get your cameras working :P
Do Not Flash Gapps
Report any bugs found; currently the only bugs: theme chooser force closing and weird "glitches" in the ROM. Which both will be fixed in the next update...
I can't wait for the EVO V 4G; I can practically taste it...
just flashed. this rom is really liquid smooth :D cant wait for the nxt update :) cant wait to see ur ics tweaks austrie :D i found some bugs with the wifi? it doesn't scan a list of nearby wifi. also nav bar isn't working even after rebooting.
Yeah, WiFi turns on, but none of the networks are listed.
i believe this is how u fix wifi. let me noe if it works. first turn on wifi then reboot. after reboot go into wifi. nothing would appear but scan n add network i believe. click add network n add ur network. after that click add. n the list of networks would appear. it worked for me. u can try adding any network to see. i added my own network to connect to n it worked. lmk if this worked.
