This is a beta release of CM10 for the Optimus Elite so please don't expect this to be 100% stable. You may get random reboots and lockups or you may not. Before flashing this rom I recommend you make a NAND backup just in case.
About (Taken from Cyanogenmod website)
CyanogenMod (pronounced sigh-AN-oh-jen-mod), is a customized, aftermarket firmware distribution for several Android devices (See above for supported devices & how to install CyanogenMod on said devices). Based on the Android Open Source Project, CyanogenMod is designed to increase performance and reliability over Android-based ROMs released by vendors and carriers such as Google, T-Mobile, HTC, etc. CyanogenMod also offers a variety of features & enhancements that are not currently found in these versions of Android.
What works:
What's partially working:
What's not working:
Issues:
F.A.Q
Q. Do I have to format my data?
A. If you are coming from a rom other than CM9 then yes you do but if you are just updating to a new CM9 build then no.
Q. How do I use my external SD card to install apps on?
A. Go to Settings>Storage>Menu button>Storage configuration>and check the box. After that you will need to reboot the phone.
Q. What settings do I use to get tethering to work?
A. Device-Profile: Generic ICS/JB (wlan0)
Change Setup-Method: WEXT (ad-hoc)
MSS clamping checked
Routing fix checked
Want to report a issue you are having with the rom? Then use getlogs.
[APP] GetLogs - Get dmesg, logcat, radio, etc with one click! - xda-developers
Will update this post later
Change Log
Credits and thanks:
Cyanogenmod
LG
Dorregaray
G60madman
Downthemachine
Giantpune
Starkraving
and everyone else I missed.
Patches:
Issue tracker:
Issue tracker
Gapps:
Dev-Host - gapps-jb-20121011-data.zip - The Ultimate Free File Hosting / File Sharing Service
Virgin Mobile:
http://d-h.st/g43
Sprint:
http://d-h.st/c3c
Screenshots:
Comming Soon
While donating is not required to use this rom it's always appreciated
Donations:
What works:
- Audio/speaker phone
- Headset/headphones
- Calls and texts
- Touchscreen
- Lights/brightness
- Offline charging
- External SD
- Bluetooth
- Wifi
- Proximity sensor
- Overclocking
- Tethering using an app called "Wifi Tether for Root Users" from the play store with the settings used in F.A.Q below.
- Mass storage
- Camera (Finally!)
- Data (stuck on 1x but get 3g speeds. Currently setup to always show 3G)
- NFC ( NFC tags and google wallet are non functional.)
What's not working:
- You tell me.
Issues:
- you may have random reboots or lock ups or you may not.
- Google Wallet doesn't work and opening it causes nfc to not work until you do a reboot. Will fix this soon.
F.A.Q
Routing fix checked
Change Log
HTML:
12/31/2013
Add ARMv7 - and especially Cortex-A9 - optimized string
Ignore some errors checks, they always occurs because broken GL drivers
Fix log spam: Failed to open libwvm.so
Triggering EarlySuspend based on BackLight brightness
Allow purging of asset bitmaps
Optimize gradient textures
Fix memory corruption in LayerRenderer::copyLayer
Plug memory leak that happens when reusing display
Fix texture corruption
Fix race condition in pthread_create()
Enable Crt screen off animation
Freed some ram
Add support for Cell broadcasting/CMAS (untested)
Fix bluetooth audio routing (untested)
Kernel undervolting support
Wifi mac address fix
add option to exit to homescreen after call
Other thing I forgot about
11/04/2013
Initial release
Credits and thanks:
Cyanogenmod
LG
Dorregaray
G60madman
Downthemachine
Giantpune
Starkraving
Patches:
HTML:
Camera fix
http://d-h.st/Uq2
bluetooth audio
http://d-h.st/TIX
Issue tracker:
Issue tracker
Gapps:
Virgin Mobile:
http://d-h.st/g43
Sprint:
http://d-h.st/c3c
Screenshots:
Comming Soon
Donations:
; it loads and I can interact with the game but the display is blank. Tried a variety of things, reinstalling and such, but no dice. It worked fine on CM9.
