edodson84
Android Expert
Theres still a few details that need tweakedlooks pretty well themed too me
Are u gunna port dis ROM over to the aweTheres still a few details that need tweakedmostly stuff nobody will notice
I just found a themer package called Team Blackout and been playing it with all morning. Really pleasing themes on the eye, just a pain because you have to uninstall all the apps previously installed/updated from Google Play, install their updater app, choose their themed apk's and it flashes them into recovery for you.. Pretty simple just a bit time consuming. Check em out @ TeamBlackout.com. Anyway, I'm psyched about this new rom and will flash it and be back in touch okay? Happy Holidaze by the way.I need themers/devs![]()
That's correctQuestion while it flashes...There are no other zips to install in addition to this one correct?
Thanks im glad u like itLoving this ROM brother. You integrated and bundled ’everything’ I regularly use into a nice, neat package. Honestly doesn't need much more theming and perform and functions really well. Nicely done man.
U having any sms issues??I've been on this device non stop 24/7 since I flashed this ROM. Everything is running great and is playing well with 3rd party apps and mods. Awesome.
U having any sms issues??[/QUOTE
No, but I'm using CM Sliding SMS.
Going to disable tinted status bar and re-check gravitybox related settings to confirm and will check back.Okay, so I'm having some fc's specifically when I use the action bar. I've repeated this issue whether using the XDA, android forums or Spotify apps and widgets.
Try clearing cache and dalvik in recovery... If that doesnt work get a log as i am not experiencing this issueOkay, so I'm having some fc's specifically when I use the action bar. I've repeated this issue whether using the XDA, android forums or Spotify apps and widgets.
My rom includes the partitions so u can flash a stock activated device on any android versionUm.. #1 - No. It's based on KK 4.4.2. & Partition updates were required to upgrade from JB 4.1.2 and function correctly.
