saidiadude
The file named btfix.zip (a few posts ago) is for Bluetooth. I don't think you need musicpatch.zip now. I didn't install it. I'm using the default launcher.
Experiencing crazy lags and hold ups on the phone. IDK my low phone memory may be the blame I will try cleaning it up and seeing if that helps.
Do you have Google+? I had to remove it because I was experiencing the same thing. Also had an issue with an older version of ChompSMS but an update fixed the problem.
If you would look a couple of pages I asked this question
https://s.basketbuild.com/devs/BaNkS/GApps/4.4.4/
. Edit: I broke something and decided to do a full wipe and reinstall, camera now works fine.
