Well after playing with 9 and getting nowhere I decided to attempt a build of cm10. I'm using your device tree, and dropped the files from there phone in vendor, but for some reason the build will not complete. I'm running Debian testing. Did I over look something, or do you think it might be an issue with my OS?
You could try Build Box. I recommend the mint 15 version, the installer works better than the ubuntu version.you gotta set up the build environment. there are things you gotta do to the os to prepare it. packages you need to install that dont come with it. also you do know that the vendor files are pulled by a script
http://androidforums.com/warp-sequent-all-things-root/723643-os-build-box.html
