Root [rom] cm11 update fix lcd issue
The Lg Lte 3 is the Korean version of the Lg F7. So they are virtually the same phones!!! So most roms that work for the Lte 3 will work for the F7.
Yeah I even found a working Lollipop rom on Baidu that flashed and everything. Too bad I couldn't get texting and calling to work.
I believe you have use the signal check pro app. But if could send the link. I'm currently trying to fix my LG F7
Yeah, switching the network mode only seems to make ril glitch out even more. I can find it, just hold on. Searching "US780" on Baidu gave me some fruitful results.
mhm will soon but when I installed a f260 rom it bricked my phone bad now when I plug into my PC it says "QHSUSB_DLOAD"
These aren't F260 ROMS. They're made for this phone on a different CDMA network I believe. Or else this one person who seems to be posting the ROMs is trying to do us a big favor.
Either way it's clear through the broken translated english that these ROMs are made for US780's.
I didn't think this phone was brickable really, but thanks for the info. I'll be more careful even though I haven't had any problems.
Flashing the zip listed here along with the boot.zip (I didn't flash the recovery because I was scared and didn't want to ruin the working recovery I had) worked fine for me on my US Cellular Optimus F7.
If anyone makes some headway on getting signal to work, let me know.
http://tieba.baidu.com/p/3500832378
(third post down has the link)
Yea idk how I'm still trying to fix it. Just stick to this cm11 rom but if you know anybody who knows how to fix this can you get them PM how
Wait, is RIL working on this CM11 ROM? The ROM listed here is identical to the ones I've found on Baidu with the same signal problems. Signal Check Pro briefly fixes the problem and then ril starts glitching on and off for me.
Also, idk anyone. Maybe Chevanlol could help? I know he quit, but this seems simple enough.
Yea use signal checker pro and change radio info to cmda it only gets you 3G and 1x
