remicks
So here we go again folks, another cm12 post. If it gets buried oh well, if not kudos.
This is EXTREMELY alpha. You know the usual warnings and whatever, so let's get to the fun stuff.
ACTUAL THREAD LOCATED HERE: http://forum.xda-developers.com/showthread.php?t=2945535
[ROM] CM12 UNOFFICIAL BUILDS by TeamBliss
Install instructions:
Be on an aosp/cm based rom
Factory reset in TWRP (DO NOT WIPE SYSTEM)
Flash rom
Flash gapps
Flash SuperSU beta
Enjoy
I finally got this ROM to boot for my gsm m8. The whole time all I needed to do was be on the stock 4.4.4 firmware. Op please make a note of this
Sent from my One using XDA Free mobile app
For those having issues flashing:
**Nandroid backup
**Format Data (wipe SDCARD)
**Flash DH's modified firmware
**Flash DH's GPE ROM
**Factory reset after booting up properly
**Flash cm12 and lollipop GAPPS
What works:
Wifi
LTE
GPS
Text/MMS
Calls
Bluetooth & Bluetooth audio streaming
What doesnt:
Do not disturb mode kills sound, reboot to fix (@pimpmaneaton)
Stock camera (Connects but does not take pictures) Use Google Camera, it works fine
Probably a TON more, report in thread please
Links:
ROM
Alpha 1
http://downloads.gigglekat.com/bliss/cm12-remicks/tested/cm12-m8-alpha1-remicks.zip (remicks)
Alpha 2 (Using TeamBliss Lollipop manifest and changes)
http://downloads.gigglekat.com/bliss/cm12-remicks/tested/cm12-m8-alpha2-remicks.zip (remicks)
Other builds (These builds are direct from CM source with the fixes and changes from post #3.)
https://www.androidfilehost.com/?w=files&flid=21446 (bracketslash)
GAPPS
http://downloads.gigglekat.com/bliss/cm12-remicks/gapps/gapps-lp-20141109-signed.zip
SuperSU
2.23
http://download.chainfire.eu/624/SuperSU/BETA-SuperSU-v2.23.zip
2.25
http://download.chainfire.eu/627/SuperSU/BETA-SuperSU-v2.25.zip
Sources used:
https://github.com/cyanogenmod
https://github.com/TheMuppets/proprietary_vendor_htc
https://github.com/TeamBliss-LP/android_device_htc_m8
Brought to you by TeamBliss
As per usual I take no responsibility if any of my suggestions cause your device to brick, explode, melt, raise your house payments, shave your dog or pack up and move to the Bahamas.
