Root [ROM][CM9 KANG][Alpha] Updated 3.5.5---6/27/12
you guys need to really try out the flash player 10.3 I provided sometime ago. Is a lot smoother and has no problem showing videos such as the green/red lines on some sites, and works with any program that requires flash player, even the stock browser.
it would be helpful if someone got the installer to add the library files automatically so that there's no hassle on having to manually add them and give them the proper permissions.
just a suggestion. If interested look for the "I want adobe flash player back" topic or I can repost the link here. Just let me know.
@destiny
did you happen to test if it worked? i think i may have installed flash but i dont quite remember which version..if the flash 10.1 version works i will add it ..
@abraham
which bootanimation do you want bro and ill send it to you..ICS or CM9? the flashable zip ill upload tommorow will have the CM9 bootani
@destiny
No is not flash player 10.1, is flash player 10.3 that shows as flash 11.0 when installed.
So johnny I've had a couple of hours to play around with this thing and let me say for an alpha this bad boy is jumpin out tha gym....I'm not sure how but the first one I downloaded was corrupt and booted but was so jittery that the screen was impossible to see..it wasn't until the second try that it booted normal....antutu benchmark sittin just under 2000 at about1800 and also a suggestion....scrap dolphin hd it force closes to the point that I couldn't even log in....plus it stores the cache on the phon......I suggest using dolphine mini it hasn't force closed or froze the phone once and caches to a server..
...many thanks to u and hroark
slowing animations down and playing with cyanogens options helps out..also i noticed...and it could just be me but, the longer i was using it the smoother it got..ill check into to dolphin mini..i like dolphin becuase i thought it had like a built in flash..could be wrong though
Update..Thanks to Inigomontoyasr no longer need a sdext partition to use this ROM, if you flash it...if you restore it you will still need one untill i update my CWM images:D
very nice... That would probably fix the issue with encryption with kernels that mount data to SD.... Could the next person that does a clean install try and see
very nice... That would probably fix the issue with encryption with kernels that mount data to SF.. Could the next person that does a clean install try and see
i did a few clean installs wiping cache...dalvik and factory reset/wipe...wiping my sd card of data and partition..flashed three times and had no issues..booted everytime no issues..:D
Does this Run at 946 mhz right from the boot? My phone seams to jam contantly with anything over 800 :( Is this able to run at a reasonably usable speed at 800 mhz? Thanks!
wear the kernel in bro...start out at 800 mhz and gradually build the speed up over a few days...900mhz is a pretty reasonable speed to keep it at..inless your benching then you can jack it up..every phone seems to react differently to OC..my phone will OC to 946mhz no problem..my wifes will not go over 900mhz without having a few small issues
It runs fine at the default 800mHz. I use this as my daily driver(can make due with the broken features)and I have it oc'ed to 925mHz. You may have to adjust the animation speed to your liking. As others have stated you have to ramp it up over time. Though some of our chips just don't like being overclocked.
Just wanted to add, even if you can't clock past 800, Kato's kennels (and any oc kernel, since they use his modifications) offer several new governors and i/o schedulers... it's not all about the speed :thumbup:
Trying this ROM out and mostly smooth.
Couple questions, the camera doesnt seem to work with the CM9 and Telenav and camera won't load from Bloodawn's apkinstaller (email and task manager loaded fine).
Anyone have this issue or an fix?
edit: i see that camera is listed as not working in initial post
not to sure honestly bro...camera is a problem with most cm9 ROM's currently..except for some htc phones i think they were reverse engineering the camera drivers from different android OS to make it work with CM9..but i think samsung phones have to wait on Samsung to release the camera drivers
as far as your other few apps..have you tried pushing them with ADB maybe? or possibly Root Explorer
