Root [ROM] Condemned CM7.2 V1.2 2/3/2012
CondemnedSoul
Welcome to Condemned CM7
(Yes.. another CM kang)​
This ROM Is built from CM source and modded a tweaked for performance by me. This ROM right now is using stock CM kernel.
*credits*
Cyanogen - Source
workshed
Conap
gnarlyc
wildstang83
The Eris and Incredible communties
I'm sure there are others as well. If I've forgotten you please let me know.
Bugs - You tell me
*Downloads*
Condemned CM7 V1.2
Gapps are already in the ROM... No need to flash them.
CyanogenMod merged Changelog
Screen Shots
As always. What you do with your device is not my doing. I'm not responsible for anything you may do to you device. Your warranty is now void.
Changelog:
2/3/12 - resynced with CM source. Adjusted tweaks.
1/14/12 - resynced with CM source
1/8/12 - Initial release.
Yes and no. Whenever I go away from it, I miss the camera. That's about it.
It's really frustrating. I can't believe Android phones can't come up with better cameras and photo software.
That being said, whenever I do use a Sense based ROM I still use a launcher over it anyway (almost always)
Cam works on CM7. Just sucks compared to Sense-camera. It's CM9 it doesn't yet work on I think.
I used to use LPP exclusively, but the options available in ADW and GO drew me to them. What I found is ADW is fancy but choppy. I don't like choppy. GoLauncher EX is what I am using now, very sweet and smooth.
Also a big fan of the multicon, but lately it's a few most-frequently used apps on the dock, a clock and battery widget, maybe a couple other widgets (calender, Pandora, Widgetsoid) on non-home pages. Everything else in the drawer.
BTW, I'm using my Eris for sh*ts and giggles lately. Works pretty well actually!
I like the seven homescreens in Launcher Pro Plus. Other than that GoLauncher EX looks pretty good except for the homescreen transition bounce.
I turned my Eris on a bit ago. It really is quite useable.
Have any of y'all ever tried Zeam launcher?
It is quite clean and minimalistic.
