Root [ROM]CyanogenMod 7.1.0 for Samsung Galaxy Pop/Mini GTS5570
Yes i know how to do that :) The partitioning can be reversed. I know how to do it on linux since i'm a linux user. On windows should be pretty much the same. All you need is a partitioning program on your pc. I use cfdisk or gparted on my linux. And you can just remove the sd-ext partition and add the free space left from the sd-ext to sdcard :)
Of course you need to plug in your sd card.
You can make a bootable cd disk of gparted and partition your sd card there :)
Hmm...i'm not sure how it can be done in windows cuz win does not detect the ext partition. i tried easeus partition master and it detected only the fat partition but i didn experiment further but maybe there cud be a way.
Yeah... Ext partitions are for linux not windows only some partition manager can open and manage those partitions. I recommend to make a bootable usb drive or a cd with gparted. And with it you can partition almost every file system :)
you can view Linux etx partion in windows with the help of third party tools/application like Linux reader. For more info Google 'view Linux partion on windows' or similar query ..
Added Screenshots and overclocking kernels and many more... Please see the first post of this thread!!!:)
I think its normal ... And thanks but your reply at xda forum didn't work. I'm still without swype and it is now bugging me very much!!!
Then how its working fine for me?! I think you have flashed with other MODS or other patches which are not allowing you to use swype. I have just installed CM7 and Gapps.
ok thanks. I'll try flashing that and see (I've flashed the later one previously for google apps)... Aren't you having any problem using it like not auto spacing, etc... It is working like it worked back on froyo?
It works like a charm :-) Very few minor bugs are there, but still a lot better than Stock one :-)
how can i make my kies detect this cyanogen mod?.. kies does not detect my phone.. i need to take all the hp number.. omg.. plz help..
Sorry, but thats not possible with cm7. Since cm7 is developed independently with stock rom...
If you want to use kies use parasmi rom( supports fm too) or andro-id(not so sure) roms....
If you want to to return your saved backup export your contact in kies as .vcf (or similar format) and copy to sdcard and import contacts from this file in dialer, your contacts will be restored.
Till date my battery was discharging at the rate of 3mv, but now its discharging rapidly at 4mv. What might be the reason?
P.S: I am on CM7
