[ROM] CyanogenMod 7 for the LG Optimus M MS690
Status
Not open for further replies.
cm7 stuck on boot screen. was working briefly after installing rom. i just installed everything in order, and rebooted after each install. then it all seemed to be working okay, and now stuck. i can boot into recovery, but i have to take the battery out to get it to stop the cm7 boot animation hang up.
edit-1
found one with an earlier date, checking now for most recent image (the one you link to above). will see if i still have the problem afterwards.
edit-2
worked like a charm. fiddling with it now. you might want to take down the link to prepaid androids. the build you have there is a month older, and has gb 2.3.5 instead of 2.3.7...unless you already have as i cannot get to the page now. ;-P
Thanks for all your hard work.i was just wondering if you found a fix to the headset issue with the cm7 rom.
Thanks.
Status
