DISCLAIMER: Please note that I will not take any responsibility for any loss of data or the malfunctioning of your Xperia X8.
Read the instructions below twice before attempting to install this Custom ROM. There is a chance you might "brick" your phone.
SPECIAL THANKS TO:
KUYAGAOL
CYANOGENMOD TEAM
XPERIAFAN 13
Xperia X8 devices can now install CyanogenMod 7 RC1 Android 2.3.5
CyanogenMod 7 RC1 Android 2.3.5 Features:
196 MB FREE IN INTERNAL MEMORY
* Back Button Ends Call
* ICS rotation animations
* ICS animations
* On/Off option for ICS rotation animations
* Gingerbread's screen on/off animation
* Loop Ringtones
* No Bootanimations (now CM7 default)
* Ultra Brightness
* ADW Launcher by CM
* OverClock
* Undervolt
* SdCard Cache Size
* More option on VM heap Size
* Send Mic Mute to Audio Manager
* Camera Button play and pause music on lockscreen
* ext app2sd
* Custom text on carrier level
* Bubble, Ravamped, Holo and Blade stile for ring lockscreen
* [NEWS!] All windows change with the theme, including the volume bar and the phone menu options.
* ThemeChooser now available from Settings/display
BUGS: Radio (working on fix for this bug for V5 release)
You can read about the features...here... <---
Requirements:
- Rooted Xperia X8 E15i NOT E15a
- xRecovery installed
- ClockworkMod Recovery*
- SE Stock Kernel
If you are stuck in a boot loop it's because you have got an old baseband xxx006
Download and flash Baseband 015 using FlashTool
METHOD
(A) Make a backup of whatever ROM you are using ClockworkMod Recovery*
1. Restart Xperia X8
2. Reboot into ClockworkMod Recovery*
by hitting the back button multiple times when you see the SE Logo on the screen
3. Go to Backup / Restore <click><backup>
4. <reboot> your Xperia X8
5. Download:
CM7_RC1_V1
CM7_RC1_V2
CM7_RC1_V3
CM7_RC1_V4
(B) Installation of CyanogenMod 7 RC1 ROM:
1. Copy CM7_RC1_V4.zip to root of SD Card
2. Reboot to ClockworkMod Recovery*
3. Scroll down to <mounts and storage>
3a. and <format /system>
3b. and <format /data>
3c. and <format /cache>
3d. go back to Main Menu <Wipe data / factory reset>
4. Install custom zip <select> CM7_RC1_V4.zip
5. install completed <Reboot>
6. Enjoy super fast and stable Gingerbread 2.3.7 on your X8
(C) Going back to your previous Custom ROM (Are you sure you wanna do that?)
1. Shutdown and Reboot your Xperia X8
3. Go to Backup / Restore <click><restore>
4. When restore is complete <reboot> X8
NOTE*:
For those who do not have ClockworkMod Recovery
a) download ClockworkMod Recovery
b) flash the ClockworkMod Recovery zip file using xRecovery
c) reboot into ClockworkMod Recovery
RESOURCES:
ClockworkMod Recovery 4.0.1.5
SUPPORT:
SONY Ericsson Support Website
PC Companion, USB Drivers for Xperia X8, SEUS & Media Sync...
If you need any help... you can post your problems/issues here.
cheers
gabe
SPECIAL THANKS TO:
KUYAGAOL
CYANOGENMOD TEAM
XPERIAFAN 13
* ICS animations
* Loop Ringtones
* Ultra Brightness
* OverClock
* Undervolt
* SdCard Cache Size
* ext app2sd
Requirements:
- SE Stock Kernel
METHOD
5. Download:
CM7_RC1_V1
CM7_RC1_V2
CM7_RC1_V3
CM7_RC1_V4
NOTE*:
RESOURCES:
SUPPORT:
cheers
gabe
