[ROM][Deodexed][Odexed]Stock Rom!
joemossjr
This is a Deodexed and Odexed Stock Rom for the Virgin Mobile Galaxy Ring!
To Flash:
1.Install Kouma's CWM Recovery.
2.Download my rom
3.Place on either Internal sd or external
4.Select install from zip on the recovery
5.Locate the file
5.5 After flashing it will say keep recovery or somthing like that say yes
6.Profit!!???!!!
Download link: Stock Odexed Rom
Deodexed link: Deodexed
OTHER MODS!
RBHEROMAX KERNEL:http://androidforums.com/galaxy-rin...uc-rbheromax-kernel-updated-2013-08-31-a.html
AND OTHERS FOR THE FUTURE!
Thanks! I have to give thanks to Kouma, rbheromax and Hitesh and all the people with oudhitsquad!
okay cool
i was gonna work on this last night but mounting system.img crashed my linux box 3 times >:(
lets keep the work coming
Use dsixda kitchen and just use your update binary from cm 10.2 and edit the script to format ext4 and mount system and /dev/block/mmcblk0p17 and make it extract Boot image to /dev/block/mmcblock0p08 and I couldnt get two files. To deodex twframework.apk
And twframework-res.apk and I guess that made it not be able to boot
And I used your rb3 for kernel on accident lol because I had a boot.img that I thought was stock By wasnt lol
lol they will probably have cm by the we have another rom lol but imma look at the update script for cm 10.2 and see if i cant fix that error 0 i got 4 errors befor i could get mine to flash last night! error 0,7,7,(bad) 0 was because of update-binary so i fixed that 7 was because i had one of my mount points wrong (bad) was just bad transfer to sd card and the other 7 was because it was trying to put the boot img in the tmp folder and the delete lol so i just extracted it to the correct block
@joemossjr
someone on prevail 2 side said this rom works out of the box
you should prolly make them a thread
