Root [ROM] Droid 3.0.0 - RC2
messenger13
Android Expert
Didn't see a thread for it, so I thought I'd create one.
DROID 3.0.0 - RC2
You may have to register to reach that page.
Description
Changes Since UD 3.0.0 Beta
- Updated build to 2.3.2 (sms bug fixed)
- MASSIVE performance improvements since 3.0.0 beta (faster, much more memory available)
- Made a lot of changes to the new theming engine
- Added fix for cdma phone signal issue
- Began Work on New UDLauncher3 (dustinmj/anderweb/blackdroid)
* Fastest 3D launcher on the planet
* Long press for customizable shortcuts
* Customizable number of shortcuts,
* Customizable launcher style
* Customizable launcher background
* Scrollable widget support
* Cleaned up code, made a few changes to launcher workspace
* (Full screen mode, Resizable widgets, Customizable number of screen, hide icon labels, and double tap to show previews still to come,)
- Added new scrollable galaxy s notification widget (customizable from ud settings - cvpcs)
- New Overhauled Music App w/ 5 widgets(Josh Stone)
- Phone and Messaging Lockscreen options are now "Phone and Custom App"
- Phone and Custom App now works with rotary lockscreen as well as the tabs lockscreen (Sven Dawitz/Blackdroid)
- Sound On ->> Vibrate On ->> Sound Off - Toggle On Lockscreen
- Rotary lockscreen + Phone and Custom app = new rotary lockscreen layout (hint:pull down)
- You now get rotary answer widget when rotary lockscreen enabled
- Removed Carrier From Status Bar and made clear button bigger (scroll to bottom of list to access clear button)
- Added Maket Apps Installer (by kmobs)
- Even more work done on UD Settings Overhaul (not fully complete)
- Porting UD Theme over to new theming system (not fully complete)
DROID 3.0.0 - RC2
Description
Have you loaded it yet?
I'm also running this. Its very smooth and fast, no fcs or random reboots. I am enjoying it, however the softkey back doesn't seem to work for closing the on-screen or touchscreen keyboard. Home button sometimes takes two or more presses to work, the hepatic feedback works every time any softkey is pressed. The extra UD settings and about phone seem to be missing from the settings menu. No issues with losing 3g. Music players all seem to work. A good rom with very few issues that I've found so far. Battery life is very good however I can not tell what state or level its at until I plug my phone in, guess ill need a battery monitoring app.
Is this the same RC2 that was discussed in the RC1 thread?
Are the accelerometer and camera (and vid recording) working? All the sensors & radios working?
accelerometer is a lot quicker than LFY and RC1. the light sensor working is really nice too. seems pretty snappy. so far seems really nice.
loving this ROM, but not being able to access the full UD settings menu kills me! i know you can add shortcuts to get to them individually, but even then, there seems to be far less options than in the FroYo versions. i hope he is working on this for the next release... i never use my camera anyway. :p
Hmm, I really want to switch to a GB ROM, but I can't until I have all the functionality I have on 2.2 (including camera). Are there still no ROMs out that have everything working? Are they close to fixing the camera issue yet?
i am pretty sure jeffv2's Gingerbread has everything working.
what works
- Block ads by default
- new galaxy s scrollable power widget
- camera
- on/off animation
- accerometer
- gps
- browser
- usb storage
- 3g after calling
-light sensors
http://androidforums.com/droid-roms/258275-jeffv2s-gingerbread.html
Off of HIS website. Sorry if he's not keeping his own information current. :confused:
weird, got a link to his site? i can't find it anywhere. i was considering making the switch while i wait on a fully functional UD version, but if the LEDs are out, i won't bother.
From the horse's mouth:
"What Doesn't Work:
-light sensors, use power control for temp fix on kb lights"
For what it's worth: I'm running CM7, build 18 (1/28/11) and all (including light sensors and kb lights) but camcorder is working...downloading build 19.
CM7 nightlies have been flawless for me. Camcorder FC's, but honestly, I've never tried recording video with my phone until people were looking for ROMs with working camcorders, in which case I tried it out.
Welp ... after about 12 hours, this ROM's battery life is proving to be horrendous!!! Perhaps the worst I've ever experienced. Time to move on. I'm going to try CM7's build 19. Here goes nuttin...
Been running CM7-18 for the last day and it's running pretty well. Getting good battery life. Way better than I was getting on UD2.5.
Camcorder is the only broken function, afaik.
If you're switching to CM7, I'm on Build 19 with LV 1.25Ghz kernel at 800 max and 250 min ondemand. The battery is absolutely incredible with this kernel. I recommend ChevyNO1's kernel from the Rom Manager.
Hey so I'm trying this 3.0 out and I dont have the ultimate settings or cant even look up what version I have... sucks... I can't modify the led notifications... think I font have all the nice stuff it has to offer...
I HIGHLY recommend trying the 'CM7 nightlies'. That ROM is up to Build #30, and is pretty near flawless. Checkout the "CM 7.0 Nightlies" thread, or Click Here for a mirror site of all the downloads.
I was going to try it ... but there sure is a long list of bugs that people are still experiencing with that 'beta'. Just sayin...
Well you know how long i have been around here, and i have had not one issue. Well, one issue is the Battery Life is the Best by a long shot of over 100 ROms i have ran. On my Third Day, unplugged this morning at 7 am, Moderate usage again, i am at 90% Still. Crazy battery life.
To clarify, are you saying your battery only depleted 10% over the course of 3 days with mixed 'moderate' usage? Or are you saying it's your third day using the ROM, and you're getting good general life (need a starting point for reference)?
Do you have a screenshot of your battery usage stats?
