Root [ROM] EVO V 4G Stock ROM Deodex/Odex
jmz
Disclaimer: Flash this ROM at your own risk. I am not responsible for what you do on your device. I left this stock to provide a base for anybody that wants to use it. Mod this rom how you want. Just please remember to give credit where credit is due.
This is a pure stock rooted rom. It has items like busybox, init.d support and so forth. No apps were added or removed. Both Odexed and Deodexed versions below.
Enjoy
Download
So this is like the stock rooted V 4G ROM? Meaning that it has all the VM programs and stuff like twitter and facebook and Sense preinstalled?
This is like you pulled it out of the box but its rooted and the other items listed in op
Thank you very much! I hope you continue this work in the future when updates roll out (assuming they roll out).
Thanks jmz! I made a nandroid backup as soon as I installed 4EXT, so my backup should be bone stock. I will keep this on file in case I ever lose it. Backup was almost 800mb though! Used to the 100mb triumph roms! lol
Yeah sense is heavy. But hey. It is a lot more sexy than pure stock. I know that comment will start a war. Lol
I'm starting to like this version of sense. The only thing I can't do is the sense mail app. I need to find the apk for the stock ics mail app if that's even possible.
Thanks for the work JMZ.
Question though. What app did you use to make these Zips? They get errors when I try to extract them using either 7zip or WinZip. The central and local headers don't match. The MD5 checksum listed on the goo download page matches the md5 that I generated to verify that my download was good. I also redownloaded the files a couple of times to make sure.
I just downloaded your VM Shooter rom to see if I could extract the files from there and that one extracts fine so it seems that these files (both the odex and deodex zips) are somehow corrupted on the server side--just fyi.
I had to open it in Linux to get it to open, I'm not sure what the exact problem was.
Regardless, you can then re-save it and open in windows.
If you don't have a linux computer you could boot from a live disk (cd or thumbstick).
I was able to do it in Windows 7 I used WinRar
I really have no idea man. I'm pretty sure it was just like every other Rom I do. Winrar, zip, normal compression. Never heard that issue before. I just tested and could open it and extract just fine on my windows box.
Thanks for the answers. I'll try winrar to do the extract. If necessary, I'll have to use my linux vm as Leslie Ann suggested, I suppose.
