thunderkiss65
- Are their any custom roms for the indulge, i have Cyanogenmod7 on my lg optimous from metro, Sure would be nice to customize the indulge.
Can we get an idea?? A month or 2??
Nowhere near that long.
We need an unrooted, updated user to stop by IRC ASAP.
Just an observation of a stock Indulge vs. an Indulge running the Basix ROM...
For starters my twin brother and I have purchased Indulge phones. He left his stock and I put the Basix ROM on Mine.
We both charged up our phones to a full charge and put them in CDMA ONLY MODE just to see whose battery would drain faster.
Now keep in mind ...we both made sure there weren't any widgets pulling data and turned off syncing of email and other things that would drain the battery.
After 6 hours his battery meter was still all the way filled or at 99 percent on the stock Indulge on my Indulge running the Basix ROM my phone read 38 percent battery????
This is with going into CWM and erasing the battery stats and rebooting. That is just a huge difference to me though!!
Once again...just so I am clear...there were no apps that were running in the backround other than what normally runs, data sycining was off, wi fi off, bluetooth off etc.
did you wipe the stats when the phone was at 100%
Most likely his battery readings are off.
Fun little thing to have him do: restart the phone. His battery meter will drop like a rock! I've seen this. I've done this. You don't want this...
Also, the actual battery icon is not to be trusted. Watch as his battery icon shows about 80% of life left and plug the charger. It might read less than 60%! So yeah, don't trust that icon in the status bar.
Do the test again, but just wait and see which phone actually *dies* first. If you've got the time, of course.
Also... what kind of battery life are you guys getting on the basix ROM WITH 4G enabled and say medium usage....
please post your results so I have an idea. thanks!!!!
funny story, before i wiped the battery stats MULTIPLE times untill i felt it was accurate 'enough' , it use to drop 30% almost everytime i rebooted, and i got konannys rom. if your having this issue you might want to calibrate the battery the proper way
Are you talking about wiping the stats in CWM after the phone has been charged to 100% while the phone is off??
i did that (calibration) a few times after i realized just wiping the stats wasn't going to cut it. Even now some days i'll look at my phone and see the battery at 70% then after 10 minutes or so i'll look at it again and it'll be at 29, when it does that it'll stay in the 20's for a good 4 hours lol. This is after a bunch of battery calibration attempts.
And that is actually not battery drain - simply an odd battery, or hardware not picking up the discharge until a certain refresh point.
