alexcool25565
Member
Yes but you can get that app in pandaapp.com
What you mean?
oh wow that was stupid im sorry... lol![]()
It boot or noOk here is the problem i changed the WiFi icon color it installed then i just got random crash errors of different stuff written in japan i rebooted and i passed the green android guy then the android letters didnt show just the light of the screen... Dont know whats wrong with this
That crash happen when you change thing in systemui.apk so if you keep change stuff you will see that all the time
I never waited for it i re installed the rom totlh made. if the crash happens will it still work or no?
Yes just made sure don't use the battery and the 4g 3g 1x and the status bar that don't work because they don't have the same name of the one you have in your system
but for some reason the app keeps crashing when i open itOkay i was able to change the signal icon from the blue to a orangebut for some reason the app keeps crashing when i open it
Yes is a crack app that why
You use pro right
Hey for the icon 4g 3g 1x use that ninjamorph that way you can get in side systemui.apk and add those file just copy the names of the one you have to change like you just need 4 icon to change up, down nothing and up and down together that 4 icon you need to change ok
If you guys trying to edit notification bar just use romtoolbox the only thing the don't work in romtoolbox is the batterys and the 4g 3g 1x don't work the rest work fine and for that the don't work you have to edit the folder inside systemui.apk
Thanks for that tidbit of info. I opened systemui.apk like a zip file and replaced a few of my stand bar icons. The battery was the most time consuming, i had to resize the icons and our phones only have battery icons for 0%, 15%, 28%, 43%, 57%, 71%, 85%, &100%. I originally wanted to put a circle style battery icon with the %in the middle but couldn't because of this. I tried replacing the original icons with ones that go from 0 to 100, but after I reboot, my status bar disappears. Any suggestions?
Other than that, i plan on changing more icons with this method, I just like to take it one step at a time and backup often.
Here are some screenshots:
For the battery you need a battery mod program the fix that http://forum.xda-developers.com/showthread.php?t=1434061
I installed in and when everything loaded up i had no notification bar i did a factory reset but that didnt work, then i re installed your rom and that put it back so i don't know what took it out but im not going to use it and just wait for your next release.
What probably happened was you tried to theme the battery. I came across this problem also. Our battery doesn't go by 1% increments, and when you replace the stat_sys_battery_xx.png's in the systumui.apk with a battery mod that goes by 1% increments, for some reason, the status bar disappears. ( I'm working on this problem now )
I say don't quit just cause you tried only once and it didn't work. You can always just reinstall the rom if you f**k up. You may do something the next time that might work and it may help someone else out.
I've run into a lot of problems while trying to theme my phone and I've learned about about my phone by f**kin up.
hi there im very new to all this rooting business and am very confused. i have successfully rooted my avid ive downloaded titanium, rom manager, SU and busy box. i followed instructions on thread for custom rom and when i go to boot in recovery and install zip it says E: signature vitrification failed and aborts. now what????? help please im completely obsessed with figuring this out
