Root [ROM] Galnet MIUI ICS 2.2.1 Stable
colchiro
Extreme Android User
[ROM] Galnet MIUI ICS (2.2.1 Build 2, 1% Batt, No Charge Led,Vol+,Updated BootMenu)
2/1/2012, 11:16 p.m.:
MIUI ICS 2.2.1 For DX:
New Build:
2.2.1 Build 2:
Rom now reboots to clockwork from reboot menu and has an option to reboot to bootmenu, if you want to use rom manager in terminal type su then cat.jpg and then do what u want to do in rom manager, also if ur on a previous build update by going to clockwork thru bootmenu by hitting volume down during the motorolla logo
added wizardof0s new bootmenu which includes
Phone charges well off instead of auto turning on
* Bootmenu updated
* OC/UV
* Governors
* Fully functional CWM from bootmenu
* Volume Controls (change tracks with the volume buttons when screen is off)
* Power Button Reboot mods
* Reboot to CWM
* Reboot to Bootmenu
* Fixed the init.mapphone_cdma.rc file to be compatible with PB, V6, etc
* cat.jpg made compatible with new bootmenu and cwm
* ALL of the fixes and additions from previous builds
Added Volume+ instead of Dsp Manager
Added 1% Batt Increments
Radio/Data fix
Fixed Charge light
Reverted to standard Miui Reboot Menu
Added older Miui Control Panel So u can set Battery to see Percentages!
Fixed My Install script so all u have to do is wipe data and davlik (no more mounting and wiping system, Makes more stable)
Thanks to Kring789 from CM7gb for 1% and Charge light and wizard for radio fix
*Reverted to 12-9 ICS framework which fixes:
- call waiting not working
- mute during call not working
- call record notification on outgoing calls shows as not connected
- Bluetooth connection issues
- Control Panel App issues
*Added Back Gtalk
*Added Back Control Panel
*Added Googles Car Home
*Fixed Compass
*Added Scripts For V6 supercharger And PowerBoost 2.2
in terminal:
type su before script
they are pbsetup for powerboost
supercharger for v6 supercharger
Bugs Atm:
Haptic is set to off goto by default, Fix- keyboard settings and put vibrate when keys pushed enabled
To upgrade from MIUI, open terminal
type:
su
tap menu... close window
Open Rom Manager, boot into recovery
1-
format cache, wipe Dalvik cache
2-mount and format system
3-mount system and install
Formatting data is recommended, however, I did not when coming from GB version of MIUI. :D
any bugs yet? all hardware working (camera, camcorder, etc.)?
mms/sms fixed?
install instructions for .605 rooted?
download link if not in the ROM list? (NM, cant believe i missed the link up top..)
inquiring minds want to know....
Should be another build tonight, or tomorrow (soon?) with fixed boot menu, but with Jakebites removed. Beans is just finishing it up now.
mms/sms fix I believe there's a patch for some other rom that fixes that. Sorry, I don't use that. You might want to inquire in that thread or start reading from half-way.
:D
Camera I think still needs focus on infinity, which works fine for me.
Also read that mounting system before install isn't needed any more, but that's how I installed it and doesn't break anything, so the OP may change.
I haven't played with mine. Flashed, then had to go to my brother-in-laws for supper.
EDIT:
BeansTown106 said:
just finished it up any ideas on how to make just the rom available for dropbox to u guys im done with hotfile they just cancelled there pay per download and i had 20 bucks lol anyways id rather give u guys good speeds to but im new to dropbox just signed up last night
Might as well. Unless Jakebites means a LOT to you.
I was updating my post when you replied. :D
cool, are you going to submit a new post for that when it hits? that would make things soooo much easier! thanks again
I think it'll be the same link, just updated OP. :D
Only if it happens in the next two minutes. I'm headed to bed.
i'm just trying to figure out which build might be better...Wiz's on the gb kernel, or beans' with that galnet ics-ish framework? thoughts, colchiro?
got it loaded, handcent FCs, but everything else seems to be spot on. will post more later as i get into it more.
anyone have a good sms/mms app that works with MIUI?
ok, using go sms, works really good, a little confusing sending mms, but i'm figuring it out.
Anyway, battery life on this ROM is so far, the best I've run! Normal day yesterday, usual battery life would get me home with 20% or so, this ROM had me still at 74%. I would say "big win" on that one.
So far, the only FC I've gotten is with Handcent, so I deleted it and am using go sms with no negative issue.
all the apps are working so far, benchmark is decent, user speed feels pretty smooth and fast, browser is really fast. GPS and navigation working better than stock ROM and locked in faster than any other build of a 2nd init ROM I've tried.
Giive this one a shot, I actually downloaded with the browser on my phone from the dropbox site and flashed it at work (while I was supposed to be working, of course...)
Geez, doesn't anyone work at work anymore? :D
I ate thru a battery yesterday with email using 50% of it. Still got home with 39% tho. I think that was a fluke tho.
Swap over from what, GB MIUI (Wizard's)?
I was on Wizard's MIUI:
created a backup in recovery
mounted system, formatted system
formatted cache, cleared Dalvik cache
mounted system, flashed Galnet MIUI
rebooted.
Although wiping data is recommended, it worked fine for me. :D
I don't have to work if I don't want to. I am an independent contractor at an auto repair shop, so if I choose not to work, I just don't get paid for my time. Besides, it was sloooooooooooooooooow that day, lol!
Is anyones else's custom ringtone not sticking? They were working fine 2 updates ago. I've also tried doing it through the themes but no luck, the notification work just fine. Anyone else experiencing this?
rebooted.
CM7 i think :P got it set up the way i want it for now and the battery has been pretty good lately.
ok, says to set ringtone by using the miui music app when you choose the ringtone you want. makes a little bit of sense, it is after all, a MP3 file i'm using, and my others are .OGG files
so, for anyone that asks:
go to settings/sound/ringtones/(choose which one you want to change) when the list of rings appears, at the bottom of the list there will be a "select from other app" choice to make. choose the music option and then pick your ringtone. done.
thanks, colchiro, for the link
