[ROM][GB 2.3.5][Cyanoid][v 4.0.1] FINAL 03/24/2013
PsyMega
Android Expert
I have been working with a guy with a PCD Chaser over the past 24 hours and have sucessfully built and booted a creation of mine known as Cyanoid.
What is Cyanoid?
A custom ROM made to immitate Cyanogen for many android devices now.
This version for the PCD Chaser will be based off of 2.3.5 gingerbread.
Working:
All Basic Functions
Known Issues:
Screen flickers on some chasers
Code:
Unofficial Final Build 3:
- Screen flickering should be fixed
- Added System Compression
- Removed init.d support ( Makes boot hang and loop )
- fixed various theme issues
- updated system apps
- Fixed DSP Manager force closing
____________________________________________________
Release 2:
- Fixed Updater-Script that prevented the ROM from installing
Release 1 Based Off 4.0.1 Cyanoid Sources:
- Full Blown* GPU Rendering with FPS cap removed
- Tweaked Kernel RamDisk
- Official Cyanogen MOD 7 GB Launcher ported* from ZTE Skate
- Fixed Broken Init.d Support
- Fixed Updater-Script Not Wiping /System and /data partitions
- Google Chrome Browser
- QuickPic
- Removed Stock Launcher
- Removed Stock Gallery
- DSP Manager Support ported* from ZTE Skate
- Native Root Browser
- Themed Google Play Music From Team Venum ( Compatible with DSP Manager )
- Android 2.3.6 Gmail
- Voltage Control /W Overclocking up to 800MHZ (Stock)
_____________________________________________________________________________
Initial 0.1 Test Build:
- Zipaligned
- Deodexed
- Standard Cyanoid 4.0.1 GB Theme
- Init.d Support ( Broken )
- Removed All Stock Bloatware and Apps
- Removed virgin mobile start up and shutdown animations
- Stock Android Startup boot animation and shutdown animation
- CWM Flashable Zip ( Errors where nothing gets wiped were present )
SCREENSHOTS
Coming Soon
( The Following are Device specific and are to be followed 100% as stated in this thread or Cyanoid won't work as intended )
Installation Instructions
1. Wipe Dalvik Cache
2. Install ROM
3. Fix permissions
Code:
DEVELOPER NOTES
PCD Chaser Users:
- Do not wipe anything in CWM other then the Dalvik cache doing so will fail in Cyanoid being able to boot. Everything able to be wiped is formatted and deleted on the initial ROM install ( By installing Cyanoid )
- Overall Gaming and Benchmarking performance I can pretty much guarantee will at least Improve some if not vastly. Animations may appear to be glitchy, This is from the FPS ( Frames per Second) Cap on the Android OS itself being removed. Removing the FPS Cap can potentially increases gaming performance in a vast manner.
DOWNLOAD LINKS:
Thanks Dizzle, much appreciated and very thankful! I am enjoying the first tester you created, now I'm stoked for the final cut!
didnt evn know you had a chaser shizzle
I don't lol. "damianmack" came to Skyn3t IRC and asked about rooting and custom ROMs so I through together the GB version of Cyanoid for the chaser for users until you get CM7 going if that is what happens.
Anyone else getting an error code 6, installation aborted? Also. Can I get the md5 checksum for the. Zip so I can confirm I've got a good download?
thats cool.
I dont really enjoy doing traditional roms anymore. id rather build from source.
Cm7 for chaser.. its close. same black screen issue i had with recovery.
as for your status 6 error.. check the target assert. if that doesnt work.. you may need to repack the zip. sometime they become corrupt for no aparent reason
Iam going to answer the question most of you are wondering, but havent asked....
i dont think ics/jellybean is possible on the chaser.. because, the system partition just isnt large enough. its hardly enough for gingerbread
