Trident
Android Expert
Das BAMF 2.1
See more screenshots here!
The das BAMF team is comprised of Trident, ThatDudeButch, Adrynalyne, and dsb9938. erishasnobattery had a HUGE hand in 2.1 as well. Thats not to minimize the many folks that actually contribute to this project. We thank you ALL! Every penny of your support is greatly appreciated. Extremely long hours go into development of this stuff, any and all support is appreciated! If you would like to aid in our relationship counseling and beer funds, please feel more than free!
ThatDudeButch: Donate
Adrynalyne: Donate
Trident: Donate
ROM Features
- 2.01.605.0 alpha base
- Debloated (this includes VZW framework, apps, games, libs, and permissions)
- Tweaked filesystem
- Fully zipaligned and deodexed
- Imoseyon's 2.54test4 kernel
- Google Car Home
- Fully working Superuser application (thanks rmk40)
- Busybox (version 1.19)
- Kernel has init.d support, adb root, and USB debugging
- Recent apps do not appear in notification bar (thanks rbox!)
- Location reticle removed (thanks rbox!)
- Accurate battery (credit ThatDudeButch)
- Custom super quick transition animations (credit ThatDudeButch)
- Custom Boot animation (credit to dsb9938 and gadget!)
- Some minor build.prop tweaks
- Rebot options in power menu (credit to aiccucs, ported by ThatDudeButch)
- Working HTC Setup Wizard (credit to aiccucs)
- Teeter
- Wake on press of volume keys
- Automatic brightness fixed
- Google Docs
- Sense 3.0 MMS application (credit to seo)
- Sense 3.0 lockscreen with working themes and buttons (credit to seo and erishasnobattery)
- Sense 3.0 Weather (credit to seo and erishasnobattery)
- Sense 3.0 Weather wallpaper (credit to seo and erishasnobattery)
- Sense 3.0 Phone modifications (credit to seo and erishasnobattery)
- Sense 3.0 Weather lockscreen (credit to seo and erishasnobattery)
- Gingerbread menu glow
- Gingerbread crt animations (credit to mike1986 and chingy51o)
- Custom bamf boot animation by gadget!
- 5-wide app drawer
- Nuked carrier text and shrunken header in pulldown
- New shutdown animation
- Splash of Red Skin from Berzerker
- Imoseyon's test4 kernel
- Working USB mass storage
- Netflix application and support added (credit to rmk)
- HTCsense.com support
- HTC Task Manager (from Doubleshot dump)
- Working HTC Hub wallpapers
- Working HTC Hub scenes
- Setup Wizard allows wifi setup
- Dropbear SSHD and client from CM
- Bash shell
- Nano editor
- Das BAMF Toolkit (Trident)
Das BAMF Toolkit Features
- CPU Settings (configure min/max frequency; governor)
- Includes Spare Parts
- Includes Terminal Emulator
- LTE Settings (toggle 4G, etc)
- Configure I/O scheduler
- Mount system
- Mount system at boot
- Block or show ads
- Enable or disable boot sound
- Enable or disable boot animation
- Enable or disable sense lockscreen
- Enable or disable clock in status bar
- Clear cache
- Clear dalvik cache
- Clear battery statistics
- Fix permissions
- Enable uber quadrant
- Remove system applications
- Backup and restore applications
- Configure Apps to SD
- Set dalvik VM heap size
- Zipalign applicaions
- Download and install custom fonts
- Download and install custom boot animations
- Download and flash custom splash screens
- Much more coming soon!
Screenshots of the Das BAMF Toolkit can be found here!
Important Notes
- A FULL WIPE IS HIGHLY RECOMMENDED!
- This is a leaked GB RUU, it has bugs, all we can do is try our best to squash them! Flash at your own risk.
- Want a smooth camera? Overclock to 1.4ghz. This is the trick others are using to make the camera smooth in their rom.
- Setup wizard may see from HTC hub crashes. This is normal and will stop once setup is complete.
- Browser crashing? Install Flash.
- Having random reboots right after flash? This is "normal" for this leak, it will subside after a minute or two.
- This ROM REQUIRES Gingerbread radios. If you have already flashed them, great. If not, see here.
- Das BAMF is on Rom Stats! Check out the statistics here!
Changelog
Code:
[B]2.1[/B]
[LIST]
[*]HUGE update to the Das BAMF Toolkit
[*]Included Rom Stats application
[*]Includes patch which fixes the gallery icons
[*]Updated Netflix to latest version
[*]Removed Quick Office
[/LIST]
[B]2.0-5[/B]
[LIST]
[*]Netflix app and support added, credit to rmk. Yes, weather still works.
[*]Toolkit updated.
[*]Updated Sense 3.0 camera, and support libs and files. Credit to seo.
[*]Updated Sense 3.0 elements, credit to seo.
[*]Imoseyon's 2.54test4 kernel.
[*]HTCsense.com support added.
[*]Build.prop modifications and tweaks.
[*]HTC Task Manager added from Doubleshot dump.
[*]Working HTC Hub wallpapers.
[*]Working HTC Hub scenes.
[*]Filesystem tweaks are back.
[*]Splash of Red skin from Berzerker updated.
[*]Setup wizard to allow wifi setup.
[*]Updated Maps.
[*]Updated Titanium Backup.
[*]Updated Street view.
[*]Updated Google Docs.
[*]LIGHT themeing of Rosie to resemble Sense3 Rosie.
[*]Dropbear SSHD and client from CM.
[*]Bash shell.
[*]Nano editor.
[/LIST]
[B]2.0[/B]
[LIST]
[*]2.01.605.0 alpha base
[*]Debloated, which includes vzw framework, apps, games, libs, and permissions.
[*]Tweaked filesystem.
[*]Zipaligned (just once, not every boot, sorry), and deodexed. Odex and deodex perform the same after the first boot, when deodex roms get....odexed. This is merely to save space in /system and make tweaking easier.
[*]Added Google Car Home, removed HTC car app.
[*]Removed Stocks widget, and app. Google has better apps for this anyway.
[*]Superuser is fixed with rmk40's version, woot woot!
[*]Our own busybox, version 1.19.
[*]Kernel has init.d support, as well as adb root, and usb debugging enabled on every boot (even from a wipe).
[*]No recent apps on notification bar, thanks rbox!
[*]Location reticle deleted, thanks rbox!
[*]Accurate battery and custom super quick transition animations, credit ThatDudeButch.
[*]Latest maps
[*]6 bar signal mod, thanks rbox! (Doesn't work quite right yet, so back at 4).
[*]Custom Boot animation, credit to dsb9938 and gadget!
[*]Some minor build.prop tweaks
[*]Rebot options, including hot restart, credit to aiccucs, ported by ThatDudeButch.
[*]Working HTC Setup wizard, credit to aiccucs.
[*]Teeter.
[*]Volume keys wake phone.
[*]Automatic brightness fixed with my own custom values. Seems to work even better on Gingerbread.
[*]Google Docs app instead of Quick Office app.
[*]Fixed apn issue with framework.
[*]Sense 3.0 MMS app, credit to seo.
[*]Sense 3.0 lockscreen app with working themes and buttons, credit to seo and erishasnobattery.
[*]Sense 3.0 weather, credit to seo and erishasnobattery.
[*]Sense 3.0 weather wallpaper, credit to seo and erishasnobattery.
[*]Sense 3.0 Phone modifications, credit to seo and erishasnobattery.
[*]Sense 3.0 weather unlock, credit to seo and erishasnobattery.
[*]Gingerbread menu glow is enabled.
[*]Gingerbread crt animations are enabled, credit to mike1986. and his DHD framework I ported it from, and chingy51o for his windowmanagerservice.smali (this fixed the accelerometer lock ups).
[*]Custom bamf boot animation by gadget!
[*]Two ported themes for Sense 2.1 by gadget!
[*]5-wide app drawer.
[*]Nuked carrier text and shrunk header in pulldown.
[*]New shutdown animation.
[*]Splash of Red Skin from Berzerker.
[*]Imoseyon's test4 kernel. Seems to work pretty well now. Also noticed its been set to run at 1ghz again. This means camera works
[*]PCSCII.apk that works with Imoseyon's kernel (test4), credit to chingy51o. This means working USB mass storage mounting
[*]BAMF toolkit.
[/LIST]
Thanks
- Adrynalyne
- ThatDudeButch
- Trident
- Erishasnobattery
- jcase
- Team AndIRC
- Liquid
- DSB9938
- ZHP Pilot
- Gadget!
- Dr_Drache
- Our BAMF IRC Testers
- All BAMF Users
Downloads
Das BAMF NTE 2.1
Mirror 1
MD5SUM: bf2a0758f73afdeddae69d04691ae9c0
[BETA] Das BAMF NTE 2.0-5
MD5SUM: 042a01c2570b0e0ef5c6e5b6add209c7
[BETA] Das BAMF NTE 2.0-4.01
MD5SUM: 17E228D0ACEF284388BF2C1B18B24905
MD5SUM: F78BAA5C36B70259312192F607C94B53
[BETA] Das BAMF NTE 2.0-3
MD5SUM: EAD963DBB3DF90BCD81F63213F907C68
[BETA] Das BAMF NTE 2.0-2
MD5SUM: 1BBDFFD4802FCDAA0C277A1BBB6525B5
MD5SUM: BC035B7D056CABE384599629C3DF7F37
Patches (flash in recovery)
Normal transitions
Disable wake on volume keys
4 column app drawer for Rosie
Sense 3.0 camera
Stock transitions with accurate battery
Recent Apps, BAMF style
Sense 2.1 Camera
VVM
