Root ROM GB Das BAMF 2.0. NO USB CONNECT
djb28
Sorry, Wrong place for this. I forgot to select Troubleshooting..
Since loading this Rom I can no longer get access to my Phone/ SD card from USB. It makes the sound but never brings up the window to open files. Can not enter through C" Drive. I have USB debugging on and USB Drive selected on phone. Restarts on the PC or Phone did not help. Neither did other USB ports on my PC. Anything else I should look at?
There are two possible fixes for this. The first is to select "internet pass through mode" and then select "mount as disk drive".
If that doesn't work then go into the Control Panel on your PC and then Uninstall Programs. Uninstall anything that has to do with HTC, reboot your PC then plug your phone back in and it should start installing the new drivers.
^this should make it work. touch internet pass thru,then touch done. give it a few seconds. then go back and select disk drive.
