Root rom help and advise
Ok I just rooted and installed the flyX rom.
looking for assistance in adding swype back.
Also pandora is forcing close even all reinstalling it.
Does anyone have the stock rom as a zip file.
Thanks
Did you create a nandroid backup prior to flashing flyx?? If so that would take you back to the stock 2.2. and there is a thread about adding swype back to it.
I thought I made a backup but I can't seem to find it.seems like rom manager was a lot easier to use than bootstrap. I will search for the swype.
Do you have a folder on your SD card called clockworkmod?? It should be in there. And yes. I use ROM manager for making backups, seems to be more user friendly.
