Root Rom help
How can i extract my current rom (bella debloated) and make it flashable. I want to try versions of JB but want a fast easy way to restore this rom rooted debloated ready to go? Can i make it like a kdz file and use the lg restore tool to reflash? or just a flashable zip that can be used from recovery? Thanks in advance :D
Boot into recovery. Do a nandroid backup. (You'll need a CWM or TWRP recovery.) Put the backup file on your computer (or somewhere else not on the phone). Any time you want that setup back, restore that nandroid backup. It's that simple. (Restore it as soon as you make it, just to be sure that you have a good backup.)
just make a backup in 2nd init recovery the lterecovery.apk and you can then restore the backup whenever. i have a backup of cm and a backup of stock and i switch back and forth using 2ndinit recovery. once you install cm10 don't use the apk version anymore because it's already built into cm power menu and using the apk will cause morning call error.
