Root ROM Help
MTdude
Ok. First and foremost I wanna say the phone is already on HBOOT 1.50 and is S-OFF.
Can't flash anything other than Harmonia. What gives?
And now Harmonia is acting funny as well, with the notification bar at the top crapping out for no apparent reason.
What roms are you trying to flash? On hboot 1.50 you should be able to flash jellybean and Gingerbread roms.
Harmonia is an exception as I think it's coded to work on both hboots, but if you are trying to flash other ice cream sandwich based roms, you need hboot 1.58.
Are you doing a full wipe before flashing? Wipe all partitions (except sd card)?
What recovery are you using?
