Root [ROM][ICS 4.0.3] Heavenly Divine Rebirth Final (Updated 08-13-2012)
Jaay Dogg
Android Expert
It's not my fault if your phone bricks, brakes, or is otherwise destroyed. Now boot into hboot mode (volume down & power) then select recovery, (it will take a moment to be able to select recovery) Once in clockwork recovery mod (CWM) select backup. once it's finished flash rom & reboot. Enjoy :D
Make a backup, then wipe data factory\reset, format the system in mounts & storage, & wipe dalvik cache in advanced, then flash rom. May take up to 10 min. on the first boot. .
What's themed
Activation
Apex Launcher
App Sharing
Auto-Sync
Apps & Sync Settings
Backup Confirm
Browser
Bluetooth
Bookmark Widget
Brcm Bluetooth Services
Calculator
Calendar
Calandar Storage
Calandar widget
Camera
Certificate Installer
Contacts Storage
Contacts
Connect To PC
CS Engine
Calendar Provider
Chrome Bookmarks Sync
Download Provider
DCM
Download Manager
Dialer
Dialer Storage
Downloads
DLNA Middle Layer
DRM Protected Content Storage
Face Lock
Feild Trial
File Browser
Framework-res
File Manager
HTC Album
HTC Message Widget
HTC Music Widget
HTC Resoures.apk
HTC Sync
HTC Hub
HTC Hub Widget
HTC Media Uploader
HTC Message Uploader
HTC Wallpaper
HTC Linkify Dispatcher
Google Quick Search
Gmail
Google Account Manager
Google Backup
Google Bookmark Sync
Google Calendar Sync
Google Contact Sync
Google Partner Setup
Google Play Movies
Google Playstore
Google Service Framework
Mail
Maps
Media Storage
Media Share
MMS
MMS Widget
Music
Music Enhancer
My Uploads
Network Location
News
News Widget
Nova Launcher Beta
Package Installer
PC Syncronization
People
Personalize
Phaze Beam
Photo Widget
Power Dashboard
Profile Widget
Quickboot
Ringdroid
Rom Manager
Screen Brightness
Screen Timeout
Settings
Settings Storage
Setup
Setup Wizard
Street View
Sync Widget
System UI
Task Manager
Transfer
Usage
VDM Client
Voice Dialer
Voice Recorder
Voice Mail
VPN Dialogs
Watch
Weather
Weather Provider
Wifi Hotspot
Wifi Tether
& Everything Else
To get the wifi tether working, Select manage apps & force stop the wifi tether, then open root explorer & navigate to system\lib\armeabi\ & change the permissions of the file inside armeabi (libwtnativetask.so) then copy & paste the file one folder back, just out of the armeabi folder. Then start the wifi tether & you should be good to go. Open the wifi tether app & go into settings chage the profile to generic ics, then select mss clamping & routing fix then start it up.
1% battery mod added, Reboot, Recovery, bootloader, & Screenshot added to power options menu, Custom boot animation & Shutdown animation, Custom ringtones added.
Overclock Kernel link: http://2fastroms.com/downloads.php?do=file&id=125
Change Log 07-31-2012: Lockscreen fixed, Data Roaming Fix (3G is back), more theming completed in com.htc.resources.apk,
Change Log 08-04-2012: Fully themed htc.resources.apk & lots of other stuff, changed a few icons in the framework-res, Added New Backgrond for the text & font
Change Log 08-13-2012: Fixed blacked out text & fonts, Fixed Sense launcher, Fixed EPST.apk can now edit mms url, Added Dropbox, Added Themed You Tube, Fully themed the rom, Added torch light, Changed some framework-res.apk icons, Added G-Talk.
Rom Link 08-13-2012: http://d-h.st/TCr
Rom Link 08-04-2012: Dev-Host - Update Heavenly Divine Rebirth Final 08-04-2012.zip - The Ultimate Free File Hosting / File Sharing Service
Rom Link 07-30-2012: Dev-Host - Update Heavenly Divine Rebirth Final 7-31-2012.zip - The Ultimate Free File Hosting / File Sharing Service
Special thanks goes to 2fast4u88, Apache Thunder, Marc12868, Mantera,G60madman, & If I've missed anyone PM me & I'll fix it.
What rom are coming from stock kingdom or Evil Kingdom v3 optimized ? The aroma installer isn't coming on to install the rom ? I've flashing this rom off & on all day testing updates. Lemme upload you a more updated version gimmie a couple of hours
Try downloading the new version & don't wipe when you flash it I just the flashed the new version 10 min ago.
Also just noticed the wifi tether is force closing it's because I forgot to add the wifi tethers lib files to the system/lib just copy & paste the file with root explorer from the apps lib folder to the systems lib folder. If that's to much uninstall it & re-install it.
im diggin the rom for real. my only prob so far is the heavenly divine at the statise bar how do i get it off. like in your screen shots. i cant see notifications
It's not on the bottom of the notification bar ? But yes I can fix it, that would be in the system framework-res drawable hdpi, I believe its called statusbar_background or something to that effect.
Can't get this ROM to download directly to my phone? I'm new to Boost, and was wondering, is there a DL limit (such as size of DL ) on or for Evo Design 4G? And if so, can it be bypassed? Any help would be greatly appreciated :)
Not that I know if. I've gotten bigger files to DL to mine.
Ya I have the same problem, had to my use PC. Also I'm not done there's alot more to theme & features I'm gonna add
