i understand that this post would not be anything new but i thought at least add it in as i post much info on ainol roms as i can.
Christian troys post below download/other links taken out by me the source is where u can download at end of the post
Features
* UbiFS (like stock roms)
* Bluetooth USB dongle support
* USB GPS support (cp210x and pl2303)
* Xbox 360 gamepad support (xpad)
* PS3 USB gamepad support (hid-sony)
* Generic / chinese (Pantherlord / GreenAsia) gamepads support (hid-pl and hid-gaff)
* OpenVPN support (tun)
* Veno congestion control algorithm
Instructions
* Unzip the content of this archive and put it in the root of a MicroSD.
* Put rom (cm9_elf2_$DATE.zip) and gapps (gapps-ics-20120429-signed_ubifs.zip) files inside internal or external sdcard.
* Turn on the tablet keeping pressed VOL- and POWER untill you see the green droid.
* Select "Wipe data / factory reset" (you can use volume rocker to move up/down and power button to confirm).
* Flash rom (cm9_elf2_$DATE.zip), gapps (gapps-ics-20120429-signed_ubifs.zip) and, if you're using a different device, the required compatibility zip.
* Now select "Reboot system now".
* Enjoy CyanogenMod 9!
-Changelog-
2012-09-22
* Integrated all fixes from "0915 update" release
* Added possibility to hide signal bars
* Change build.prop property ro.disable_permanent_hidebar=0 to ro.disable_permanent_hidebar=1 if you prefer the "original" behavior of the combined bar hiding option (it hides only when apps request FULLSCREEN flag, like on plain cm9)
* Updated upstream sources
Rom - Gapps
Alternative kernel for ELF-II (1.5GHz CPU, 400MHz GPU) v1.0
Compatibility zips for other devices
* Aurora-II v1.2
Known bugs
* TBD
FAQs
* If you wanna increase the microphone capture volume open terminal emulator and after typing "su" type "alsa_amixer sset Capture 63" (it's a one shot command, it will be stored in alsa's configs)
* For a better gaming experience use "performance2" governor (you can change it from cyanogenmod's "Performance" settings).
Sources
* android_device_ainol_elf2
* android_frameworks_base
* cm_bootable_recovery
Screenshots
-Old changelog-
2012-09-15
* Some minor changes under the hood
Rom - Gapps
2012-09-15 update
* Fixed touch problem with some games
* Changed WiFi wake lock implementation
* Minor change to ril daemon
* Removed 20 pixels "frame" limit from touchscreen's driver
Elf-II - Aurora-II
2012-09-13
* Fixed FC on license check of some games (specially gameloft one)
* Bluetooth dongle now supports hotplug
* Cyanogenmod's option to hide status bar now will permanently hide it (not only if the app requests the FULLSCREEN flag). You can enable/disable this option using the included ToggleBar app or checking/unchecking the option from "combined bar"'s settings.
Rom - Gapps
2012-09-07
* Fixed HDMI connection (if you wanna use the dualdisplay feature just remove the "#" character from "#ro.vout.dualdisplay2=true" entry in file /system/build.prop)
Rom - Gapps
Fixes for 2012-09-07 build
* Camera is working again
* Re-added move 2 internal SD feature
* Added a new menu entry in "Display settings" to toggle HDMI dual/single view
Fixes
2012-09-05
* Added usb_modeswitch
* Fixed audio capture
* Fixed camera orientation on remote side
Rom - Gapps
2012-08-31
* Fixed UMS mode
* Fixed USB disk mounts
* Fixed default WiFi sleep policy
* Added support for NTFS and ExFat
* Added CIFS and NFS support
Rom - Gapps
2012-08-30
* First release, pretty much everything should be working. Anyway HDMI has to be tested, I can't test it because on my Elf it doesn't work on stock rom either.
Rom - Gapps
Source :ciao:
CyanogenMod 9
Features
Instructions
-Changelog-
2012-09-22
Rom - Gapps
* Aurora-II v1.2
Known bugs
* TBD
FAQs
Sources
Screenshots
-Old changelog-
2012-09-15
Rom - Gapps
2012-09-15 update
Elf-II - Aurora-II
2012-09-13
Rom - Gapps
2012-09-07
Rom - Gapps
Fixes
2012-09-05
Rom - Gapps
2012-08-31
* Fixed UMS mode
Rom - Gapps
2012-08-30
Rom - Gapps
Source :ciao:
