Root ROM issue
The fix permissions error is because there is not a copy of busybox in the proper place... If you have Titanium Backup installed it is a very easy fix...
go into Titanium Backup and hit fix problems, this will install a working version of busybox... However it will install it in the wrong spot for RM, use an app like Root Explorer to navigate to your /data/data/com.keramidas.TitaniumBackup folder, the to the files folder.
There is a file there named busybox, copy it and then paste it in your /system/bin folder and you are good to go...
Hello, i tried it this way and then i reboorted my HTC Desire HD and now the only thing that comes on my screen is the animation of Coredroid (the rom that is on my phone), some help please?
