Root [ROM][JB][CM] Paranoid Android Ver2.53 Alpha 1 (01MAY2013)
BSydz
Android Expert
This is totally built from source code. This is JB so a lot of stuff is not working yet. Also expect another version of this. The whole source code has not been released, and they have two versions, CM and AOSP. I am working on AOSP as we speak. This is just to give you guys a taste of Jellybean. :D
THIS IS AN ALPHA RELEASE EXPECT THINGS NOT TO WORK!
After spending some time trying to set up the repo for the source code, I found that I was using a few wrong repos because of the switch PA made when they rearranged everything. The CM version got abandoned and this is the actual CM version 2.53 instead of 2.99. Everything is set up and ready to build. Source can be pulled with code below.
General info:
To be honest, this is not tablet mode at all, it has nothing to do with silly build.prop hacks.
This is the first and only Android rom to feature true Hybrid mode.
This rom lets you scale and project every app, every widget, even systemcomponents individually.
Remember, android is modular, everything is an app: Lockscreen, navigationbar, dialogs, popups, keyboards, widgets, and your regular apps of course.
Apps have the capability to switch into various designs or layouts according to the device they run on.
This can result in a complete new experience as many apps will transform to the better.
Paranoid Android - Home
https://github.com/ParanoidAndroid/android
Triumph specific:
https://github.com/MT-ParanoidAndroid/android
repo init -u git://github.com/MT-ParanoidAndroid/android.git -b cm_jellybean
Thanks to isaacj87, Tickerguy, Whyzor, mantera, g60madman, rukin5197, and anybody else that was involved with Triumph developement. Thanks to the whole Cyanogen Mod team, and the Paranoid team.
I'll update with more info in time, just need to figure out how things are running. There is just too much for one person to test, so let me know how it goes.
INSTALLATION:
If you have never flashed a ROM before, follow these instructions.
If you are on a rooted ROM, it would make it easier to transition, if you backup all of the apks in data/app with a root explorer. Then you don't have to download them and you can just install them from any file manager.
For those that have CWM or TWRP Recovery already installed follow these steps
1. Backup
2. Wipe Data/Factory Reset
3. Flash Rom
4. Flash Symlinked Gapps for JB
5. Reboot
6. Enjoy
pa_triumph-2.53-01MAY2013-183418:
Second release.
Changes:
First boot may get stuck, it is the graphics driver, I just use adb reboot and it works fine, you should be able to pull battery and should boot fine after that.
Wifi saves password and reconnects after sleeping.
Other fixes across the board.
Not working:
3G
GPS?
HDMI
Camera will NOT preview but will take pics
Video does not record or play
to be continued...
pa_triumph-Alpha-2.53-01MAY2013-183418.zip
Old Builds:
pa_triumph-2.99 Alpha-1-10JAN2013-122041:
First release.
Not working:
3G
Wifi won't save password
Camera same as CM9 will preview but not take pics but will take pics in panorama
to be continued...
pa_triumph-2.99 Alpha-1-10JAN2013-122041.zip
Ok, threw this on (making a nandroid backup of the last one), it looks nice. Seemed to want me to login to Google twice. Have setup setting to Phablet to see when it was like.
Mobile data seems not working
Wifi works, but doesn't auto save settings so doesn't reconnect.
SMS Test worked (out and back)
It's currently downloading 73 apps from Google. This could be interesting.
wow bsydz excellent work! were you able to put this 3g fix into place: androidforums.com/triumph-all-things-root/606349-rom-mtdev-cm10-build-20120825-alpha-3.html#post5215348
EDIT: I tried it, did not fix 3g
Camera works similarly to how it does in CM9.
Glad to see another JB ROM out. I really hope we can fix the WiFi issue because it's getting on my nerves. Has a real weird error in logcat as well..
But glad to see you get this out and running!
My goodness the devs for triump,h are great first we we get the camera real close to working then we get paranoid ics and jb roms I'm happy to have my triumph and the devs for it. I was getting scared at the loss of devs and the slow in development, so much so I started learning to develope myself. Which I'm almost to the point I could start contributing to the community. That's a good thing but even better is the renewed vigor I see in MT development.Im pretty happy with my phone and until I can afford another 300 dollar phone it will serve me fine especially for 25 a month. I've put my phone side to side with newer "better" phones and see very little to run out and pay for. I'm sorry I ranted off topic a bit but this past week has made a flash junky like myself very happy. I love having something new and exciting to play with. THANKS GUYS.....
Where did you go to learn developing stuff I want to try developing for the triumph and evo v
:smokingsomb:
all over really..android development and source pages , Java and their tutorials , all kinds of threads on the development and general sections of xda forums , and all kinds of pages I ran across on google .. I did a lot of researching
and searching some more, and tons of reading. I suppose the first thing I would suggest is reading on how to setup your android development kit or sdk, and start looking for tutorials it depends how far you wanna go. You can learn Android Java c++ and any other programming languages you get interested in if you really want get into it but it takes time and patients . If you need more info there's general sections here to ask and others will know more than me or pm me and I'll answer what I can and point you to some links
:smokingsomb:
ok thanks imma look into it and whenever i need some help ill pm ya
this is a good start Bsydz, I won't be able to test anything that requires the network data connection, but the wifi is kinda wonky
running 2.99 Alpha-1-10JAN2013-122041 for me on that one the wifi doesn't save passwords nor does the 3g data work. Videos don't play, just sound (file or streaming). Headphone jack not working
wow thanks for giving us a taste of a new rom! I've been running it for about a day so far and the only problem that i found that others aren't reporting is how it displays the multitasking cards. Thanks again for all your hard work BSydz.
Thanks for the feedback everybody! I just don't have time to test everything, so this is a great help. So not working seems to be wifi saving passwords, 3G, video playback, and the multitasking icons not filling. I now there are a lot of other things not working with the UI but right now I need hardware feedback. I think PA switched gears to AOSPA which is based off stock android code, so I have been working on that version but it is a pain switching from CM to AOSP, so I haven't even got a full build yet. But this can help with CM10 in general, just knowing what hardware works and what doesn't. CM10 is more complete UI wise, so some of the PA stuff may not work. Thanks again.
You got it! but don't forget the headphones. when i plug them in, the speaker keeps playing the music instead of switching.
im testing to rom for bugs, my wifi wont turn on, then the device force reboots, im going to try a reflash and test again
This ROM rocks!!It's running smooth as of now.So far no 3G,no wi-fi tethering(couldn't use anyways without the 3G),video doesn't work (Download MX Player and use S/W codec for most videos),camera previews but doesn't save (like in CM9 use 3rd party app),and headphones don't work.This is all I found.Calls work,bluetooth works,apollo music works,wi-fi works but won't save passwords.If I find more I'll post.Also used Skype and for some reason I got logged out.I had let it set there without using it while logged in.I'll keep an eye on that too.Anyways great work!!!If you fix the 3G I will make this an everyday ROM
ok my triumph isnt activated so i cant test 3g speeds, but the rom is is very snappy and after modding the build prop( VM heap is at 96m)and ROM Toolbox app(cache from 128k to 1024k) this feels like a brand new phone! and the UI speed matches my sisters Samsung Reverb running ICS!! im very impressed with this ROM...now im going on a bug hunt
Known Bugs to date-
1. Camera orientation is not centered (i know)
2. No-video playback in third party apps
3. off centered multi-task menu
4. Headphone jack doesnt switch
5. Wifi doesnt save password
6. 3g is non functioning
