[ROM]JetMOD
Status
Not open for further replies.
varun.chitre15
Android Expert
Greetings guys!
Well, after building the recovery I wanted to be first to utilize it
ROM has been tested and works flawlessly :)
First tester:akhi33
Prerequisites-
1. Micromax A75 :p
2. ClockworkMOD recovery by me installed
3. NAND Backup made by the recovery just incase :D
----Features----
1. Pre-rooted
2. Zipaligned all apks for better RAM utilization
3. Added init.d support
4. Added Adobe flash support
5. Unsecured boot image
6. Added VM tweaks
7. Added Supercharger script
8. Added RAM script for better multitasking
9. Forced Launcher into RAM memory
10. Enable hardware acceleration
12. GPU rendering enabled
13. Incremented network buffer values for faster network
14. Forced sleep when screen turned off for better battery life
15. Many battery related improvements
16. Added hosts file for block ads
17. Increased SD card cache size for faster SD card
18. Added Nano editor+sysro+sysrw
19. Added Bash- A better replacement for sh
20. Decreased the call ring delay to zero for instant call arrival
21. Increased wifi scans for better battery life
22. Enabled Stagefright support
23. Increased Dalvik heap size to 48mb
24. Added EXT2 support-WORKING!!!
25. OTA updates- From here updates will arrive directly to your phone now no more checking forums and downloading and flashing the update- Coolest feature-Thanks to aquariusoft
26. Added Link2sd
27. Added ADW Launcher
28. Based on Stock ROM by Micromax
29. Odexed the ROM for faster boot times
30. Added new boot and shutdown animations
31. Disabled boot sounds
32. Enabled Zipalign on boot
33. Enabled purgable assets
34. Added all regional languages support viz: Assamese, Bengali, Hindi, Oriya, Malayalam, Tamil, Telugu, Gujarati, Marathi, Hindi
35.New Dirty ratios for better battery life
36. Debloated
37. Added Busybox
38. Much more- will add when I remember :D:D
OMG How to install this?
Well, here are the steps
1. Download the zip from above link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe Dalvik Cache
6. Install zip from SD card
7. Fix permissions-This will take approximately 1 min
8. Reboot
9. You are travelling inside Jet 3.0 :D:D
My mistake :(
I forgot to add file manager
Don't worry, I am a good guy :D:D
I have made a flashable file manger for you all:D
After Installation just flash this
------Instructions to flash this------
1. Just install zip from SD card no need of other things :)
But this has to be done after installing JetMOD 3.0 :p
Hey I want to reward you for your work how can I?
Just press the Thanks button no need of reward or anything as such :):)
File Integrity
MD5:
1E47B6C11D6F963893C3C466E2735738
SHA-256:
29F6F62C52391380EAEE33F50B3C4806DDE48936604935CBE79AF2BCB60EA560
Tiger: 4C67AB4F15689678675AE0B4000B65FC94E087F17D5ECB89
Whirlpool:D0B60FD947922CB462710B6D2493D180345FA952609B23B7FA84C01872A4FDF8B6AEAF203E2ABCB9C3C50B11645BFDD8A35B4253D49F39EC8ADAC9B6F59EC762
---Changelogs---
v3.0.3 13/May/2012
Code:
1.Updated OTA console with tons of improvements and additions
2.Moved the OTA to system/app for prevention of being vanished as reported by some users
3.Now access the ROM thread by just tapping home page in ROM section
4.Beta fix for Wifi Hotspot
5.Now 'about phone' will show JetMOD version
Link: [URL="http://www.indiasporting.com/apks/Varun/A75/JetMODs/Jet_3.0.3.zip"]Jet 3.0.3[/URL]
v3.0.2 30/April/2012
Code:
1. Fixed Gtalk force close
2. New Gtalk with Video/Voice call
Link: [URL="http://www.indiasporting.com/apks/Varun/A75/JetMODs/Jet_3.0.2.zip"]Jet 3.0.2[/URL]
v3.0.1 29/April/2012
Code:
1.Added Google play store
2.Added Google Talk
3.Added some other OTA info
4.Fixed few other bugs
Link:[URL="http://www.indiasporting.com/apks/Varun/A75/JetMODs/Jet_3.0.1.zip"]Jet 3.0.1[/URL]
v3.0.0 29/April/2012
Code:
1. Initial release
2. Lots of performance related improvements(Detailed info on OP)
3. Number of battery related improvements(Detailed info on OP)
4. Adobe flash support
5. init.d support
6. Busybox, bash, nano
7. Regional languages support
8. OTA updates
--Hall of Credits--
1. To all respective developers for their valuable scripts- zeppelinrox, Juwe
2. ninadchaudhari - For his ultimate rooting workaround for A75 as well as for being a representative of the section
3. Credits to respective developers whose apps are included in the ROM
4. Bruno martin, dsixda and all other developers whose utilities I used
Note:This will be updated as per requirement
woooooooow!! A bolt lightning ROM.....thanks a lot. Started downloading.....will report once its done + flashed it ;))
to go into recovery mode....
switch off the phone
start it again by pressing Power switch and Volume up key
now u will enter the recovery mode
There u can manouver, by pressing the volume up/down keys for up/down....and power butten as "enter/accept button"
to go back to the previous menu....u can either press the back key directly....or goto the "move back" key by manouvering and pushing the power switch.
Hope that helped ;) :D
But there is no option thatreply from sd card..instead there has update from SD card.
I have selected the option but no file found..no change appeared..Thogh the file is ion the memory card..Please help urgently...
You have flash new recovery by me for that
See this
[RECOVERY][UPDATE][WORKING]Clockworkmod recovery v5 - Android Forums
See full thread for how to flash that new recovery
And yeah flash v1 of that recovery
Thanks for reply
But I cant find much option like u..
Please elaborate the procedure..
I have downloaded the file-- [RECOVERY][UPDATE][WORKING]Clockworkmod recovery v5
What to do with this???
How to get those screen with so much option??
Please help
@akhi33
Can you give me some screenshots?
Can u write a full review for the ROM including various aspects like performance, adobe flash, stability, battery life?
Thanks for reply
Please help
go advance
Currently I am using [ROM]~* UB-A75-1 For A75 ! *~
There are only 6 options in recovery mode-
reboot system now
apply upodate from SDcard
wipe data/factory reset
wipe cache partition
backup user data
restore user data..
Now what to do??please help..
My phone is rooted ..There is super user apps...
Download my new recovery and put it in mmx update package.
And start SP Flash tool and tick on recovery and flash it.
Then you are done :)
@akhi33
Sudiptaid hasn't flashed the new recovery yet.
He is on stock recovery yet
How to do that??
plz explain in detail..
I am a Medico person..
So its hard for me to do all those stuff..
When I am going to select--
apply update from SD card..an when I am locating the file..it shows..
E:signature verification failed
Installation aborted..
Status
