Root Rom&Kernal Explanations please
zim2704
Ok so I'm new to the fascinate and have been reading everything I can about the way to ROM and all the good stuff I was used to doing on my OG Droid.
My problem is I keep seeing a bunch of Rom builds like EA15/EB01/EB16/EC10 and so on.....Also radio or modems like dl09, eb01 and others
My question is how do I know which one I have currently loaded on my phone. I know the rom has it listed on the thread but outside of that is there a way to tell?
What does it say when you go to Settings > About phone? Should be the last 3 slots at the bottom which give out what you're running.
It gives me a baseband version(S:i500.04V.EB01) - explains the radio/kernal but the build numbers.
So can I take it you can flash seperate kernals/radios for different rom builds? I'm just so used to the OG droid that I'm having some growing pains learning the ropes with the samsung process.
