[ROM] LG Ally Bionx 1.0.0|SDK8|AOS2.2.2|Themed|Deoxidized|SmartStart|O verClocked
Status
Not open for further replies.
how would I go about getting google play(marketplace) to install on this rom.
It keeps saying not installed after i try and install it from APK's I have found.
note: I dont use the phone, the phones just used via wifi as my mother replaced it recently allowing me to tinker with it and various roms without worry about her getting bent over me changing her phone from what she was use to....:)
thanks for any help you can give, been wanting to toss some free games on it to play around with(also so she can see that android can be good, my fathers got her convenience that iphones are the only way to go because thats what his coworkers say)
The android market is forever gone, it was replaced with google play. Google maps you have to install yourself.
Oh okay thanks Ryan. You had any issues with the Wifi? Whenever I turn my screen on and try to access the internet it won't connect to the router for about a minute or so. Thanks for the great work though!
Thats a battery saver script, whats happens is when the screen goes off, the wifi goes off. There might be a setting for that in spare parts. Not entirely sure
Just updated from the last stable version you released couple months back and... wow!
Freaking amazing! great job man!
Edit: Never mind about the font, got it working.
Thanks again for the great work.
Phone started malfunctioning badly, but then I flashed my back up of your ROM (I was using Velocity 1.2.1) and I'm not going back I think X)
I finally got around to installing 1.0.0, and I'm pretty impressed so far. As you suggested, rgocal, I left the cache and dalvik-cache alone, and my security key app works just fine. I went with the IceBreaker version, because I like the theming on the status bar icons. However, I switched to the Sense homescreen theme, because the Sense icons look better than the Blur icons. But all that aside, I've gotta say - this version is a substantial speed improvement over 0.8. I dunno exactly what you did to make it that way, but I like it.
I mean, it's so fast, it even makes the Facebook app bearable to use.
You guys have done a great job. It's been a fantastic ride through the beta's with you. Great rom, great support. When I ever do upgrade I'll hope I get lucky enough to see it supported by people as great. Thank you, and bless your endeavors.
next 2 builds i have planned are a slimmed down version for people who dont want all the extra bloatware Nd tethering apps. thebother version will b a wifi based version.
Will the Wi-Fi based version be Android 2.3.6 like gingerbreak?
Im working on it now.
Changes
-removed 3rd party apps and bloatware, kept phandroid and 360 theme
-removed tethering apps, in return, removed shortcuts in settings.
-motorola icons in settings
Now the rest is up to you guys, would you want this or not.
-remove 360 ui? Throw in normal launcher.
-new theme? Or keep original.
-Remove any extra system apks ive added for memory.
-add anything to your liking.
-update anything you see needs attention.
-remove 360 ui? Throw in normal launcher. Yes, please
-new theme? Or keep original. Keep Original
-Remove any extra system apks ive added for memory. Make it so you can uninstall fancy widgets?
-add anything to your liking. The transparent background for settings seems to lag the phone a bit, and is sort of a distracting. Not a huge deal
alright, wishes granted.
Bionx Holo changelog
-removed 360 launcher
-added HC launcher
-removed 3rd party apps/personal aps (bare bone)
-rebuilt android settings manifest with motorola icons
-ported motorola ics theme with my enhancements
-maintenance check on bionx app
Edit: found some mistakes. Correcting them then releasing
looks like i'm a little late for the party, but i'll jump in anyway.
360 - I actually dont mind it at all, i find it to be smoother than other launchers i've tried so far.
Tehering - cant live without it, but working with pdanet anyway.
Other - Personally i got rid of phandroid, the little bar on the side (forgot the name) and a couple of other apps, but again, not a big deal and easy to remove / add.
On thing: a way to fade / darken the background when using apps would be nice. for example - the music app, if you have any light background its almost impossible to see anything, as everything is written in white. the only way i found around that was changing the background to something that is mostly dark or any colors that dont blend with white.
Status
