sorry about the delay
Making sure its nicely done
Holo Is Live
Give it a go
Phone started malfunctioning badly, but then I flashed my back up of your ROM (I was using Velocity 1.2.1) and I'm not going back I think X)
One more thing to note: is it possible to have the camera button on the side back to normal ? or at least have the option to choose if it's used as an "end" or camera button.
It's interesting that this question goes unanswered...... I've had the same question and got ignored the same way.
decided to root my ally since got upgrade coming in a few months.
One thing i noticed right away Rgocal.
The ally is a slider. but the Bionix homescreen will not rotate, tried turning rotate on and off but still will not rotate. If i go into anything it will rotate just fine but the home screen is locked in long view. Might seem minor but the slider keyboard is the biggest reason i got the ally in the first place and almost always have it open while in use. i love the the ROM and how it performs but this is a deal breaker for meOnly other thing i have noticed and this is real minor, the alarm clock sounds are extremely muted when setting an alarm.
hopefully the home view rotate is an easy fix because i'd love to keep the rom.
randomally, i will try that. i don't know much about launchers so will have to do some research. hopefully that will resolve my toggle issues as i love the performance on bionix.
Update now available.
Remember to clear cache after applying
It switches it back to normal
When i get to fixing the links,
Il probably be releasing a patch to clear up any future annoyances in bionx.
Right now, im working on updated software for future builds of bionx and hope to include the software in the patch.
Something fresh for people still on their allys.
Altho obsolete, the ally still fun to play with. Il nvr dis it.
