RedBunnyJAV
I found a file on the LG Open Source Website the other day. Just enter LS840 for the model number.
This is the file I found:
LS840(Viper)_Android_ICS_4.0.4_r1_US_Sprint_Opensource_LS840ZVG.zip
In the .zip are 2 files. An Android.tar.gz and a Kernel.tar.gz file.
The README says to compile to must have the Android-SDK installed and basically you just compile the LG/Sprint Viper ICS with the Android 14 in the SDK and walla you should have ICS 4.0.1r1 ready for your LG-Viper.
The main problem with all of this is that you have to have Linux running to ./compile the way the readme says. So over the next day or two I plan on setting up linux under VirtualBox or some other way to do it on Windows.
If anyone want to try, just download the Viper - ICS from LG/Sprint on the link above (the've taken it off the site for some reason) and let me know how it goes.
