Root [ROM] Liquid Thundersense v1.0
After playing around with this for a while it seems a little buggy, after restoring account settings with TiBU i got some FC's and then I had to do a battery pull, once it rebooted I wasn't able to access gmail, kept FCing. Looks like Liquid has some kinks to work out still.
try doing a fresh install,and only restore apps with titanium. restoring system data can sometimes lead to phone confusion :eek:
Yeah, I was wondering why bad stuff would start happening after restoring system data.
Havn't tried re-installing this yet. Is anyone having more success? Has anyone played with this some more?
Rule of thumb whenever restoring system data with TiBu. Only restore the data that is marked in green, anything that is in red can and will cause issues. The green data is system data that is the same across ROMs.
I learn something new everyday here, thanks i was wondering what the difference was in the red an green data saves.
No problem, that is why I love this place. When I first got into this with my OG Droid, this place was simply awesome it terms of help and knowledge. It can be a bit overwelming at first, but once you start you will find out that you learn a lot simply by reading threads and trying stuff.
