hey guys,
this is not mine, but a new LOTK rom!!!!!!
here is the original thread:
http://forum.xda-developers.com/showthread.php?t=2222421
mikshepard said:This is lightweight and fast JellyBean 4.2.2 AOSP-based, with tweaks from CM10.1 and AOKP. I like it as it is a powerful ROM with many settings and options but without feeling too bloated with features that many don't use. You won't find a PIE option or Per-App dpi settings here, but you will find many customizations to make this run exactly as you see fit. Here's some of what it offers:
-8 Lockscreen targets
-Notification bar and drawer transparency settings
-Custom carrier label
-Battery bar
-CM Power Widget
-Hardware key custom actions (including back button)
-Disable lockscreen widgets and/or usability hints
-Quiet Hours
-DashClock Widget built in
-Widgets Viewpager (a kind of locker at the bottom of the screen for widgets that can be called by a hardware -key assignment, very cool)
-linaro -O3 flags
-Dark Slim option (a built in theme to darken everything)
-much more...
Changelog
4/11/13 Nightly -
-Removed default music app and added Apollo
-Added Launcher2 tweaks by JamieG71 (will feel much snappier)
-Compiled busybox with linaro -O3 flags (may increase speed)
-Added CM LockClock back in, for those that don't like DashWidget
-Fixed bash error "void endpwent()(3) is not implemented on Android", good riddance!
-Compiled command-line utilities: ssh, scp, netcat, openvpn, rsync, and htop into ROM
-Added Terminal emulator into build
-Added a few other tweaks I'm forgetting here
THIS BUILD IS VERY SMOOTH AND SNAPPY, ENJOY!!
4/5/13 Nightly
-First release. Compiled kernel with linaro -O3 flages, swapped in my themed blue DeskClock, added extra alarm rington for some morning madness..
