Root [ROM] M-Bravo V6.1
Im Going to try this because im a huge fan of monsteria++
so how do i install this.... Should i install this like installing lunar gen or is it different???
Stock++ based, and installs the same way.
I still suggest wiping the Data, System, and Cache partitions. Also Wiping Dalvik Cache.
Also if you want to see great performance, install the 360launcher addon. It's worth it.
Is this cm7? If I flashed this would I be able to change the theme from that, and do you have to wait a certain amount of time before using the market.
I'm uploading to Dropbox now give me a few minutes.
It's not CM7 based and it has everything working.
Edit: It's all up!
ok so i installed i love the look of it so far but i don't think the camera fix worked for mine i installed it with odin cwm did i do that right and what is the difference between DB and the other one just wondering if you do not mind me asking
DB is hosted on DropBox.
If it doesn't look like the stock camera then your ok.
oopss i forgot to mention that it force closes when i launch it .. i just tried re-applying the patch mount/system as well
p.s. i love the flow of this its nice and smooth
What's Force Closing? Is it DSPManager? If so delete it or Freeze it, it doesn't cooperate with Beats.
Interesting, wipe the cache and dalvik cache.
alright ill give that a try right now
hmmm didnt seem too work ima do a fresh install again.
edit: fresh install worked i didnt put the fix all patch or the camera patch on yet maybe i installed it wrong or i wasnt suppose to use it ?
The patches just fix the minor updates the UI. The All in one is the easier choice.
