Root Rom Manager
civicsisedan
Android Expert
So I just opened Rom Manager for the first time in a while and wow are there a lot more options then before.
In IHFP69 section I already downloaded the new notification bar...
And all thegoodies for 2.2 are there.
Dont know if anyone has checked it out lately but you definitely should...
Yeah, ihfp69 is a really good developer and is always adding more themes and goodies for his roms which is why I've been sticking with Sky Raider for a while now.
Quick question about all the goodies. If I've already flashed and installed the 2.5.2 vanilla, if I just want to install a new notification it seems like ROM Manager is going to reflash everything. After I download the notification bar I'm prompted with the ROM Pre-Installation menu again. Maybe I just need to man up and redo my widgets. I hope I didn't miss something obvious but is there just a way to install one of the notification bars without having to reflash the whole thing from within ROM Manager?
no when flashing the goodies, dont clear data, and i dont make a backup either, you could, but probly not needed.
I thought so. But the fact i was prompted for it made me think twice.
/crosses fingers
Edit: Phew... that worked. Made me nervous for a second.
Any advantage to usin' the SkyRaider ROM from ROM Manager as opposed to just downloading from, say, XDA?
Streamlined interface. It downloads right to your phone and it installs in clockworkmod just like if you did it yourself. And you don't even need the premium version of ROM Manager for SkyRaider.
Ah. I ask because I already have it installed on mine, but tempted to use the Manager for it. I'm guessing the updates will be automagically applied?
seems like after downloading a new notification bar with the battery percent in circle my phone seems more sluggish..
anybody else?
i downloaded a new notification bar for my skyraider and it changed my background. now I have some lame picture of grass. I miss the sweet robot wallpaper I had.
