Root rom markers
amazin1988
will anyone be making a stock recovery rom cause the one they have now really put me through some stuff i dont think my phone is messed up but it up but it did something to the android market and something with the gallery im gonna flash back to playful god rom and see if anything changes but i really suggest if u flash dont use that stock recovery they have cause it seem to not work all the way not saying its his fault but it will drive u crazy ijs
There is no stock recovery. You wiped over it when you installed CWR.
Also when you first flash you should of, it was said in PG's post, make a back up before doing anything.
have you tried doing a factory reset? also get titu from market and wipe market and relaunch market.
if i could i would factory reset my phone and make a backup of 'fresh out box state' then post it for everyone... but sadly i am in a similar situation (i think) i lost the original backup of stock rom & recovery, and when you try the unrooting script it didn't remove cwm... but the device still works if i keep it rooted... so waiting till zvc gets root before i get the update(fix) lol
As I have said in another post, this was a problemthat was encountered while testing gingersteem. Mt developed the stock ROM as well, but there was almost no testing on it, as our priority was getting the custom ROM out. I still haves my stock backup, later tonight when I get home I'll restore it, factory reset, then make an all stock backup for everybody with this problem, until the ROM is fixed. If somebody else can beat me to it, that would be great lol
I will have to make 2 different backups, 1 fir cwm, and 1 for rzr. I personally prefer rzr but I know most people will using cwm and a backup made by 1 will not work on the other
