Root [ROM] Mate5
PlayfulGod
Extreme Android User
DISCLAIMER: This is a MODDED' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, heres Mate5, a modded stock ROM for the Huawei M835, rooted, deodexed, and tweaked.
  • Author: PlayfulGod
  • Current Version: 1.1
  • Description: A Modded Stock M835 ROM
Added features:
  • Rooted
  • Deodexed
  • APK's Zipaligned (better RAM utilization)
  • Darktremor Apps2SD v2.7.5.2 + fix. (Class 6 or better SDCard required. SDCard needs to be partitioned for SD-EXT)
  • Dalvik moved to sdcard
  • Nano added
  • Bash added
  • custom bootanimation
  • Custom bootsplash (HackDroid)
  • Bloatware will need to be Removed manually with Root Explorer.
Changelog
  • initial Release
  • 09162011
  • recooked with stock boot.img/kernel
  • tethering unlocked
  • mms send raised from 10 to 15
Enjoy!!
Install Notes
  • Install in CWM like any other ROM.
    • Boot into CWM
    • Wipe Data/Factory reset - this may be able to be skipped, but for best results it is recommended.
    • goto Advanced > wipe Dalvik Cache
    • Main Menu
    • Install Zip from SDCard
    • Select the Mate5 zip
    • When it finishes reboot system
Links
Mate5 v1.1
Love the bootanimation but after full boot up get system not responding comming from cm7 m835w
ok so my friends phone does the same thing also the second splash screen seems to be corrupted (at least that's how it looks to me) but as far as the it booting it boots up but then it immediately says: "Sorry! process system is not responding" and then it gives you the option to choose either force close or wait no matter what you choose it just goes to a black screen and stays there like there is no home launcher however the home button does respond but it doesn't actually do anything the other buttons do not give any response hope this helps figure out the problem
If you have the jdk enviorment setup, you can run the "adb logcat" command at your cmd prompt, connect your phone via usb, and power it up. it will give you a text view of the boot process that you can copy and paste. When i break something on my phone, that command is invaluable for figuring out what happened. Not saying it will give you the fix you need but it might provide good info for others to help.
Happy modding!!! :-)
same thing happened 2 me :(
status 6 error:(
but cm7 worked:)
(FINALLY) and i think my data works, too- too bad i broke down and got the optimus m...
m835:currently running clockworkmod v3.0.0.5
installing update...
E:error in /sdcard/mate35_v1.1.zip
(status 6)
installation aborted.
any ideas whats wrong please let me know.
(status 6)
I'll have to check it out. prolly a problem in the updater-script.
installed with no problems. The OP says there's a custom bootanimation, but I'm still seeing/hearing the metropcs logo/sound after the huawei splash screen. Did I do something wrong or was it changed back to stock in the newer updates?
No, you had a corrupt download. Hopefully the only thing messed up is your boot...
I would redownload over a strong connection and reinstall but that's just me, I'm anal like that.
Can anyone help me out with this when im trying to restore a backup of my stock rom im getting md5 mismatch in cwm recovery, I want to test other roms but if something goes wrong I would like to be able to go to the stock rom
Interesting. Everything works like it should a far as the phone goes. I'll re download & flash it though & see if there's a difference. Does it matter if it's flashed through RM vs. manually through recovery?
