DISCLAIMER: By using this ROM, you understand that only YOU are responsible for anything good or bad that may come from it.
For Boost Mobile ZTE Max only.
This ROM is ported from Warp 4G SuperROM. It uses Epic Launcher based on AOSP 4.4.2, has Xposed Framework and GravityBox module pre-installed, includes Tweaked Mms.apk, KitKat AOSP Keyboard, wifi tether, KitKat themed status bar, AOSP Lockscreen, and more. Enjoy
How To Install:
NOTE: Since this ROM is unsigned, Signature Verification will need to be disabled in PhilZ recovery. This can be accomplished in the same menu as "Choose zip from sdcard". It says something like Toggle signature verification.
NOTE2: I recommend turning on Power Toggles, which gives you the notification area power widgets
NOTE3: Your device must have a custom recovery to flash ROMs. If it doesn't, please check out PhilZ Touch 6.19.2
How to use Xposed Framework:
Once the ROM is running on your device, go to your app drawer and select Xposed Installer. Click Framework, then Install/Update and give it root permission. Hit cancel when it asks you to reboot, then go back and click on Modules. Check the box next to GravityBox and reboot. Now you can open GravityBox from the app drawer and start playing around with stuff.
How To Install:
- Download stormer_SuperROM_v2.7a.zip to your sdcard
- Reboot into PhilZ recovery
- MAKE A BACKUP (optional, but highly recommended)
- Wipe data/Factory reset
- Install stormer_SuperROM_v2.7a.zip from sdcard
- Reboot
- Enjoy!
