A bug was found over on the Warp 4G thread. Gesture typing does not work. Here is a flashable that fixes it. Let me know if it works for you
stormer_SuperROM_Gesture_Typing_Fix.zip
Is there a way to just delete the SRS apk altogether? It keeps enabling itself even when I disable it in system settings.
As far as I know, the only apk related to SRS is SRSSetting.apk. You could try renaming it to SRSSetting.apk1 or something of the sort. I don't think it will remove srs but it may help somehow. If it breaks something you can always rename it back.
Where would it be located? And how would I rename it? I'm a no0b when it comes to modifying the files in the file system. Only good at flashing lol
OK I did all that just gotta reboot. Also is there a way to use the camera app that came with the stock ROM? It seems that the camera included doesn't autofocus and I'm not sure if its my phone case but there seems to be a greenish haze around the edges of pictures. Here is an example. View attachment 72985
Bummer. I will see if I can remove SRS, but I kinda doubt it.even after renaming the apk it still enables itself.![]()
It seems that even after switching to the original camera it doesn't autofocus like its supposed to.
If you still have the max camera installed, try putting these files in /system/lib. You will need to unzip, copy the files to /system/lib, change permissions on both files just like before, and reboot.
max_camera_libs.zip
edit: these files already exist, so if you choose overwrite the perms will be correct automatically. If you want to be able to easily revert in case of a problem however, renaming the existing files first is a good idea.
Did all that and still no bueno. I'm wondering if its my camera.....
Nope, but this isIts all good. One last thing, is the voicemail app the max original? I can't even open it. It force closes every time.
SRS still give in problem camera not working that good a lil grainy
Yes it did
No green
