still no data
If you wiped data in PhilZ and reflashed the rom then I don't know what to tell you. Have you paid your bill? lol
still no data
yes...lol. but do you have the original files that was changed in your rom for the boost max....i just want to flash them back and see will that help
its trying to contact network again
Edit: Do i need my sim card in the phone for it to reach the network? I took it out because i was going to send it in to zte on monday
what about the eri.xml file....did your rom automatically delete that file that was suppose to be in the data folder?
That small wipe all zip I posted removes everything the apn zip did. Flashing a new rom puts all the things you need back. Nothing else to say about it lolwhat about the fixprop.sh file that was mentioned
hey when i reflashed this rom, using flashify, the recovery worked flashed and i use the superrom zip for stormer. the phone rebooted but never came on. there is no recovery nor download mode. how do i regain my phone without sending it in. the drivers are installed for my phone and my phone read Qualcomm HS-USB QDLoader 9008 (COM12)
I don't know if you have received my first post can I have your permission to use your rom as a base wrong
Hey Superr. Is there a video using your method to root the boost max n9520? Cause for some reason i cant get it going. lol
Would this rom work on a Sprint branded ZTE Max?
I guess as long as there's no modem or radio installed it'd just be a matter of resetting the apn's.You would need to try it out. I think it will boot, but I am not sure about calls and data.
