Root [ROM] Metallic Blue Theme [ICS 4.0.3]
Jaay Dogg
Android Expert
Metallic Blue Rom
It's not my fault if your phone bricks, brakes, or is otherwise destroyed. Now boot into hboot mode (volume down & power) then select recovery, (it will take a moment to be able to select recovery) Once in clockwork recovery mod (CWM) select backup. Then select data factory reset, once it's finished select, go back, then select install zip from SD card, then choose zip from SD card, flash rom & reboot. Enjoy
What's Themed
Contacts
Framework-res
Mms (messaging)
Phone
Settings
System UI
This is the first build of this theme I have done, so if enough people want me to theme it all the way through then we'll see.:D
Rom Link:Dev-Host - [ROM][THEME] Metallic_Blue.zip - The Ultimate Free File Hosting / File Sharing Service
Not tested on sprint only boost, Do so at your risk.
Special thanks goes to Apache Thunder, Marc12868, Mantera,G60madman, & If I've missed anyone PM me & I'll fix it.:adore:
Nice work Jaay, you still hanging out over at SDX? I haven't been over there in awhile. Oh ppl, don't forget to make a nandroid before you wipe or flash anything.
I stop by every now & then, I've come a long way since my sdx day. They didn't have enough Triumph traffic so I came here & got me some skills. On an AOKP Port mission for this phone.
