Root [ROM] mumBojumBo ROM
thIsgUy20
NEW ROM FOR YOU GUYS​
First off I know somebody like what's up with that name??? Well this rom was teddytales 3DWiZ Rom but he moved on to the nexus 4 and I did to but I still got my evo v so I told him hey want me to pick up development on your 3DWiZ rom? He was like yeah! So while I was working on it I was bringing in features from other places not just touchwiz then I thought since it's a lot of stuff in this rom why not call it mumBo jumBo????
so lets get down to business......​
Why are there two different versions? putting all the launchers in one rom was making it like 200 mib! So i separated them so people can use which ever one they like!!! ***There are no differences between the two other than one has LG launcher & it's wallpapers and the other has touchwiz launcher and it's wallpapers*** In the future I will try and get a xperia version also
Features​
Touchwiz launcher for the S4
Samsung Weather Widget
LG launcher
ChaOSLauncher (both Roms)
Paranoid Android's Halo
TeddyTales TouchWiz was 4.1.2 I think well now I have brought it up to 4.2.2 with DU as base
Dirty unicorns feature's (at heart this rom is dirty unicorns so you will see a lot of DU stuff in it)
Android 4.3 Red Sunbeam Wallpaper (no more blue)
Custom GAPPS for this rom (Blacked out)
updated camera from Dirty Unicorns (if you want Photosphere ask and you shall receive)
Custom Boot Animation (Right now it's crappy because it was my first custom boot animation but it will get better with updates)
Touchwiz Sounds (I may have put them in there but if they are then they are in both ROMs but if they aren't I will get them in it soon)
Any new features in the latest (I think) DU rom is in this one
There are some build.prop and other changes changes I made that aren't in DU but you won't notice it
Default browser is replaced with Chrome and email is replaced with Gmail I replaced some other stuff but can't think of it
I thought about adding android 4.3 camera but that's up to you all which camera you want. In the future I will post flashables and you can choose from Motorola camera, android 4.3 camera, or keep the camera that's in the Rom
many more.....
What doesn't work????? In the LG launcher version when you long press down then choose wallpaper it crashes. I do believe that was my fault with all the decompiling and what not trying to get the right wallpapers in. I will fix that soon but until then you can still go to gallery then set a picture as your wallpaper from there
In settings there is something that if you press it it will force closure. I can't remember what it is but it's not anything major you probably never press it anyways. I'm working on customizing settings so that's why that problem came up
credits​
First the best girlfriend ever!! 😍ALLIE😍 for all the motivation and wanting to learn the stuff I do & putting up with me!!!
TeddyTales for giving me the keys to this rom becoming a awesome friend and giving me a few tips with this rom
Mazda and his DU Rom since this is that rom at heart
G60 I actually learned a lot from him!!
CM, AOKP, and PA for all the features and what not they have come out with
LG and Samsung for there UI's
Google for giving a awesome OS
Anybody I left out tell me I did and I will put you on here........
A Couple of things you should know PLEASE READ​
1.If TeddyTales decides he wants to pick up his 3DWiZ Rom where he left off then his Rom and this Rom will become two different things
2. I probably won't work on Ubuntu touch for the evo v for awhile. That's a hard project
!!!!!NOW FOR THE DOWNLOAD LINKS!!!!!!
GO TO SECOND POST FOR UPDATED LINKS!!​
HOW TO FLASH
You should really know how to Flash by now but....
1. Download the version you want and the gapps
2. Reboot into recovery and factory reset and and wipe cache and dalvick
2. Flash the Rom first then the Gapps
4. It does take awhile to boot!!! maybe longer then other Roms So go make you a sandwich or something when you come back it will be booted.
THESE STEPS ARE THE SAME STEPS I HAVE USED TO FLASH BOTH ROMS!!! SO IF YOU'RE DEVICE TURNS INTO A BOMB THEN YOU MESSED UP SOMEWHERE BUT I WILL HELP YOU OUT JUST ASK
IF YOU FLASH ONE ROM THEN WANT TO SWITCH TO THE OTHER ONE YOU DO NOT HAVE TO WIPE ANYTHING!! I HAVE SWITCHED BETWEEN THE TWO WITHOUT WIPING ANYTHING BEFORE
OH AND IN SETTINGS IN ABOUT DU PLEASE DON'T GO AND PRESS DU UPDATE OR WHATEVER IT SAYS I HAVEN'T PRESSED IT BUT I'M SURE IT WILL MESS STUFF UP
That's about it. Flash which ever version you want and if people start bashing saying why don't you make one rom then i'll consider it but for now there's two version's
I have a nexus 4 so I don't use my evo v for calls or whatever so any problems with sms or mms or calls then report them and I will try and fix. if you can't send or receive mms then just flash g60's mms and vvm fix. If you can't find it then ask and I'll post it
:ciao::thumb::thumb::ciao::party:​
This will be for updates and screenshots....
UPDATES & SCREENSHOTS​
8/5/13
TW-- https://dl.dropboxusercontent.com/u/69705167/TW.zip
LG-- https://dl.dropboxusercontent.com/u/69705167/LG.zip
GApps-- https://dl.dropboxusercontent.com/u/69705167/LGTWGapps.zip
I am SUPER SORRY I have been late with updates. Haven't had to much time with this ROM between giving my attention to my girlfriend and trying to get a job and I'm about to start college most of my time goes towards that. I do have another update I'm working on!!!! This update I don't even remember what all I fixed. I know I did some gapps changes and I put in g60's mms&vvm fix so no need to go flash it
**After it boots up for the first time reboot once to get visual voice mail going**
You don't have to wipe anything!!!!
new boot animation coming soon!! I just finished it I don't like the boot animation I had at first it's crappy
Excellent work dude!
By the way I have a question for you, how did you get the touchwiz launcher, and lg launcher in there?
Any special lib files or framework files? Or are they not the actual launchers, rather unofficial ones?
If you can tell me it would benefit the amaze 4g people in xda. (I made a custom rom there and I'm planning to make more. :) )
I think I may have found my daily driver for the Evo V!!!
Trying out the touchwiz version first :P
f u c k e n stoked!!! :D
I'm on the TW version. Love this ROM but have a few problems. Can't access setting through the settings button, but they work when pulling down the notification bar. Chrome won't open for me. It flashes open a white screen and then closes with no error message. And mms doesn't work, at least for me. Anybody else with the same problems or should I try again?
Ahh okay well for the MMS just flash g60's fix I tried implementing the apns from g60's fix but that didn't work obviously. As for chrome I don't think I ever had that problem when I get home I'll test that out if it don't work I'll change back to stock browser or a different one (any suggestions?) SuperAfnan the touchwiz one had a couple of libs you got to put in but lg launcher there wasn't any libs. But I did decompile chaos launcher and put each launchers individual wallpapers in them (I messed up on lg launcher that's why it force closure)
Had the exact same issues. Also when trying to update Google Search, it kept telling me that the "Package File Is Not Signed Correctly". Tried uninstalling and re installing with no joy.
I'll fix the Google now issue. I believe whoever recompiled the blacked out version didn't sign it right but I'll fix that in the next update
If that's the problem with Google search then whoever made the blacked out version didn't sign it so I'll fix that in the next update
This is a great ROM by the way. I tried both versions and actually like the LG one better. The Chrome issue doesn't bother me as I use stock anyway and will just restore that from TB. Thanks for your work.
Oh and colosssus3874 that settings thing you was talking about that might just be a launcher problem. I had that same problem when I was using buzz launcher. I think certain launchers have that problem
Looks pretty sweet! Gonna give it a go! Thanks m8!
Edit: Update Google Chrome and it will run fine. Also may want to put in the OP that 3D doesn't work. Which I'm sure everyone knows by now.
Subzero I thought I had that up there thanks for noticing. But to everybody that want to use this ROM it will be a week or two before I update it.I just got out the hospital what was suppose to be a small surgery turn out into a stay all night thing because my right lung got filled with stuff so I'm at home now. When everything back to normal I will put put a up date. It was hard enough trying to type all this
How's battery life on this I'm using angry bean right now and it's cool but battery life is low for me
I'd say that's pretty good, although I have been real busy at work and barely touched it today.
I also deleted Google now...that to me is the biggest waste of battery
8/5/13
I am SUPER SORRY I have been late with updates. Haven't had to much time with this ROM between giving my attention to my girlfriend and trying to get a job and I'm about to start college most of my time goes towards that. I do have another update I'm working on!!!! This update I don't even remember what all I fixed. I know I did some changes in gapps and other stuff. But just report errors
I was working on doing a complete settings overhaul but I started getting errors. SO in this rom it's just one little change in settings
8/5/13
thanks! I'm going to mess with this rom when I have time but I uploaded a custom 4ext theme to go with the Rom. Later on I'm going to mess around and figure out how to do auro installer or whatever it's called and give a option to try different cameras from moto x, CM's new focal camera or any camera for that matter.. ( i don't mean play store camera's)
For those wondering about 4.3 there's nothing really amazing about it I'm not even running it on my N4 but if I can I will work on updating this to 4.3 whenever DU gets updated tot it
I couldn't get it to boot.. Im s-off, hboot 1.04, and i let it sit for about 20-25 minutes trying to boot. I wiped everything (factory reset) and wiped dalvik/cache, i even tried formatting all partitions..
RedBear's Evo 3D
Thanks for this ROM! Angry Bean refugee here, the issues with the past few builds for that ROM finally got me looking for an alternative Jelly Bean ROM.
My only real issue with mumbojumbo is 4G Wimax connectivity in inconsistent signal areas. After losing and regaining a Wimax signal a time or two I get the "could not start Wimax" message, and I can't enable the main Wimax checkbox on the 4G settings screen. Toggling airplane mode has worked a couple of times, while on a couple of other occasions I was forced to reboot the phone.
Any idea what might be happening, and/or how to fix it? Only other question is how I can switch to the standard-skinned Messaging app... the red & blue color scheme is not float'n my boat.
