S
I would like to load Myn's but I am curious about what the requirements are???
I am rooted w/ Stock Rom back from August. Do I need to update the Radio or the Wimax or anything before I apply it???
Thanks
Titanium will restore all of your apps and data. Do you have the Pro version? Much easier to do a batch operation.
I always just go to the market and search and install each one. I have a list and i can move through it pretty quick...
But when you use titanium, once you restore your apps does it sync with your market and then let you know when updates come out?
I used titanium once and after i reinstalled my apps, when i went to market, it didnt recognize that i had them installed so i had no reminder when updates came out.
So I flashed the hulu, and when I try to open the ap it is just a white screen?
I've been using Myn's since RLS 1. Never had that happen before. Did you flash the most recent Radio/Wimax Combo? If so, did you upgrade you're PRL to 1.9? If so, it's not compatible with 3.30 ROM, only the latest 3.7. If you did, downgrade your PRL back to 1.77 and you'll be fine. Calkulin has a thread on XDA with all of the radios, wimax, hboot, PRL, NV, all various versions. Also, if you did indeed flash the radio combo, it is not compatible with the stock (HTC 17) kernel that comes cooked into Myn's ROM, so you would need to flash an alternate kernel such as ziggy's or Nets.I just started using this ROM yesterday. Anyone have any issues with everything slowing down when you receive a phone call?
My first 4 phone calls were fine, but today for some reason after a call everything slowed down and I had to reboot the phone. :/
What is the best way to get autoscrolling to work on webpages?i thought I flashed a new font but still no luck
If you DIDN't update your radios, I would suggest using Amon RA to do a complete wipe (data/cache/davlik cache), reflash RLS4 and starting from scratch. All of Myn's ROM's have worked better than flawlessly on my phone, although things do differ from phone to phone.
Not good for my old tired eyes.I have been running this since Sunday. Pretty good so far.
- *very* fast. when moving from screen to screen noticeable snap
- battery seems about the same for my use.
- The ROM seemed to install very fast.
How do I change back to stock font??? By mistake I think I grabbed the DarkStar/Coconut font. Good font for younger people.Not good for my old tired eyes.
Thanks
Guess I'll have to go back to Fresh if myn isn't available--can't live without swype!
Does anyone know when the next myn release is expected? Apparently my swype doesn't work anymore because it was released with the latest OTA.Guess I'll have to go back to Fresh if myn isn't available--can't live without swype!
