Root ^^^^ROM^^^ O.D.rom v.1
andriodadmirer
O.D.rom v.1
from ANDROIDADMIRER
THIS IS STOCK ICS 4.0.4
WHAT'S IN IT?
APPS
_________________
1.REPLACED STOCK LAUNCHER WITH PORTED MOTOBLUR LAUNCHER
2. REPLACED STOCK CAMERA WITH 4.2 CAMERA AND GALLERY
3. REPLACED STOCK FILE MANAGER WITH PORTED CYANOGENMOD FILE MANAGER
4. REPLACED STOCK CALCULATOR WITH CYANOGENMOD CALCULATOR
5. 4.3 DESKCLOCK.APK
6. 4.4 CALAENDER.APK
7. GMAIL WITH DUAL PANE ENABLED
8. REPLACED STOCK MUSIC PLAYER WITH PORTED APOLLO MUSIC PLAYER
9.DSPMANAGER.APK
10 REPLACED STOCK METRO BROWSER WITH AOSP BROWSER
_________________
SYSTEM
_________________
1. INTERGRATED SDCARD SWAP
2. REPLACED STOCK BOOT ANIMATION WITH MY OWN CUSTOM ONE
3. REPLACED ALL FONTS WITH KIT KAT FONTS
4. REPLACED LOCKSCREEN CLOCK FONT WITH ROBOTO FONT
5. ENABLED CRT OFF EFFECT IN FRAMEWORK
6. MOVED LOCKSCREEN CLOCK OVER A LITTLE
OFF CENTER
7. ENABLED SYSTEM NAVAGATION BAR (CHANGED DIMENS.XML FILE TO MAKE NAVBAR HEIGHT SMALLER SO IT WOULDN'T OVERLAP OUR KEYBOARD)
8. ENABLED DUAL PANE MODE OR "phablet" mode IN FRAMEWORK
9. DISABLED THE "TOOLBOX" IN SYSTEMUI.APK NO MORE TOOLBOX
10. INTERGRATED THE SDCARD SWAP SO EXT SD IS INTERNAL
________________
INSTALLING O.D.rom
1. BOOT INTO RECOVERY
2. DO FULL WIPE CACHE,DATA
3. GO TO MOUNTS AND STORAGE AND FORMAT CACHE, DATA AND SYSTEM
4. GO TO ADVANCED AND WIPE DALVIC CACHE
5. NAVIGATE TO O.D.rom AND SELECT IT
SELECT YES TO INSTALL
6. AFTER INSTALL SELECT REBOOT SYSTEM NOW
AND THERE YA GO !!!
THANKS TO LDRIFTA for the stock deodexed rom
THANKS TO JOKERPKS for the sd card swap
________________
ROM LINK
https://www.dropbox.com/s/qmoss0lypkklpvg/O.D.ROM.zip?m
How you get rid of the little buttons? You know, the home, back and menu.
Since you have it an the phone already.
